Throttle cable cut to fit???
the1969fordguyinky
Tore
Is there a throttle cable that can be purchased that is a cut to fit application?
Tore
Tore
Tore- Posts : 865
Re: Throttle cable cut to fit???
pretty much all of them.
I have used an expensive Lokar cable purchased from summit and a pretty cheap one from Autozone. Both were a cut to fit deal and looked to be about the same quality.
the1969fordguyinky- Posts : 237
I havent seen them advertised as cut to fit.
Tore
Tore
Tore- Posts : 865
My Lokar cable was a cut to fit part.
Ranch71460- Posts : 284
Tore,
Whatever brand you end up getting, opt for the black outside plastic coated, the braided steel is junk and stretches.
Travis
Travis
TravisRice- BBF CONTRIBUTOR
Tore, I have a Lokar, and it is cut to fit. I also have 4/5 other Ford style that are diff. lengths. let me know Tore,I will send you all of them and what you don't use you can give back at Norwalk.Tore wrote:Thanks guys
If it strechted on you Travis you didnt set it up right i've used those on many diffrent cars for years and not ever a problem even after 4 straight years.TravisRice wrote:Tore,
Travis
nuclearcobra- BBF CONTRIBUTOR
bbf-falcon wrote:Tore, I have a Lokar, and it is cut to fit. I also have 4/5 other Ford style that are diff. lengths. let me know Tore,I will send you all of them and what you don't use you can give back at Norwalk.Tore wrote:Thanks guys
Thanks Rick I am going to look and see how mine is set up. It looks like a 24" lockar and I will see about cutting it.
Tore
Tore- Posts : 865
Yea,you can,I did mine.
» Throttle Cable and Kickdown Cable Questions
» need help with throttle cable
» Throttle cable?
» Throttle Cable Bracket On Pro Systems Carb
» throttle cable or linkage
» Throttle cable?
