Throttle Cable and Kickdown Cable Questions
Do any of you know a good place to get these cables and bracket, and a good read and/or video on how to properly install and set these cables up?
Thanks!
Thanks!
TheFrog- Posts : 81
Re: Throttle Cable and Kickdown Cable Questions
Lokar makes cable kits for various tranny set ups. There isn't much to it. I believe you can view the instructions on Summit's site.
Quick Fuel makes a replacement throttle shaft with the ford kickdown linkage for 4150 style carbs.That is the route I am going so I can use a modified factory kickdown rod. It is a lot cheaper to boot.
http://www.summitracing.com/search/?keyword=QFT-10-4&dds=1
TommyK- Posts : 74
» impossible to run a Dominator carb and have a usable kickdown cable??
» Throttle cable?
» What throttle cable
» Throttle cable cut to fit???
» need help with throttle cable
» Throttle cable?
