impossible to run a Dominator carb and have a usable kickdown cable??
tiger
MauriSSio
i cant find anywhere where somebody is running a kickdown cable on their dominator equipped carbs. Is it at all possible to have a working kickdown linkage with a dominator?
MauriSSio- Posts : 20
Re: impossible to run a Dominator carb and have a usable kickdown cable??
WE JUST MAKE THEM,IT JUST TAKES A LITTLE TIME. hech most of the guys take them off after a year or so, and ive asked and they say, wow guessi forgot to reinstall it after converter ,or engine change,lol have no clue what they did with them,but none of the guys seem to mis them after all of this
BOSS 429- Posts : 2372
i just want to add one because i heard the kickdown provides line pressure. and when coupled with the vaccum modulator you can set the shift points so that it shifts automatically. is that the way it works? or do i just mess with the modulator?
how do the dominator guys that dont manual shift set their shift points?
my 72 torino has a dom, no kickdown, adjustment by mod valve,and gov in the trans
she leaves it in drive , just floors it
so what did you do to the governor?
Youll have to call my trans guy
815 723-0798 -bill
815 723-0798 -bill
I am pretty shure you just turn the screw in the modulator valve to set the shift points.
tiger- Posts : 272
I ran a lokar kickdown cable with my dominator/c6 for years.
I welded an additional arm on the throttle arm, pointing down like on the regular holleys. Worked great.
Greg
Greg
Greg_P- Posts : 1009
I purchased a Lokar throttle cable and kickdown for the c6.
I fabricated a small aluminum bar on the Dominator throttle linkage.
0.50" X .25" X 3" aluminum. The kickdown is below the pivot point.
The picture should be worth more than 1000 words.
68galaxie- Posts : 351
I don't run any kickdowns with any of my C-6s, not even the tow truck.
I just punch the throttle and it magically downshifts.
The race cars shift dead on at the track w/out a k/d. Super consistent.
As posted above, the adjustable modulator sets the shift point.
83-88T-Bird Guy- Posts : 1003
I thought the C6 kickdown function was to increase the internal line pressures?
A C6 expert would know better than I.
Cheers
Cheers
Just a thought... If you're running a Dominator, your C6 should NOT be the type that NEEDS a kickdown...
FWIW
FWIW
DFI429 wrote:Just a thought... If you're running a Dominator, your C6 should NOT be the type that NEEDS a kickdown...
FWIW
What?
Why not? Please explain.
What type would that be? Manual valve body?
» Throttle Cable and Kickdown Cable Questions
» Who makes a trans kickdown linkage kit for C6
» Throttle Cable Bracket On Pro Systems Carb
» Belt drive shutoff cable, shut off cable, BG bypass regulator
» Gas carb v/s Alky carb
