What throttle cable
What throttle cable
Who sales a basic throttle cable for a 89 fox?
tconnection- Posts : 866
Re: What throttle cable
I did a search and found that the 75-78 ltd 24'' will work.
Can anybody point out a basic throttle bracket for a 4500 dominator?
Have you check with the local auto parts see if they can get one for like a 84 with out fuel injection one with the carb wasn't thinking yesterday when I met you when you ask me about one. Did the valve covers work out for you with the master cylinder.
The factory cable for the 79-85 Carb'd V8 cars worked for me.
As far as a bracket, get one of the aluminum ones from Summit or Jegs.
http://www.summitracing.com/search/department/air-fuel-delivery/part-type/throttle-cable-brackets/section/carburetors-accessories/carburetor-model/4500?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=throttle%20bracket
Ok, thanks about the cable. The valve covers polished up real good and i havent ordered the brake kit yet. I was hoping summit or jegs had the offset deal. One of those scews need a little straighten.
I'm using a Throttle cable from a 75 Lincoln with a 460.tconnection wrote:Who sales a basic throttle cable for a 89 fox?
Later Mark.
Mark Miller- Posts : 1958
Thanks for all the info.
» Throttle Cable and Kickdown Cable Questions
» Throttle cable cut to fit???
» need help with throttle cable
» Throttle cable?
» throttle cable or linkage
» Throttle cable?
