Is 0.050" endplay in a c6 too much???
Is 0.050" endplay in a c6 too much??? Empty Is 0.050" endplay in a c6 too much???
Post  f100cleveland May 28th 2010, 11:25 pm
I put my c6 together today and found out that my endplay was 0.050". Problem is, I can't just swap out a thicker thrust between the pump/direct because thats been replaced with torrington bearing. I'm hoping I can find a thicker torrington bearing race, but no local shops have had any luck. I'm building the trans with Franks specs (0.020-0.045") since I'm using his v/b.
Thanks in advance.
f100cleveland
f100cleveland
Is 0.050" endplay in a c6 too much??? Empty Re: Is 0.050" endplay in a c6 too much???
Post  Gregaust May 29th 2010, 1:51 am
.050" is way too much. What about a thin shim under the torrington? Torrington do .030 shims as races to go with their roller bearing if you can get the size .
Gregaust
Post  BIGDOG466 June 4th 2010, 5:50 pm
Gregaust wrote:.050" is way too much. What about a thin shim under the torrington? Torrington do .030 shims as races to go with their roller bearing if you can get the size .
X2
How that brake work?
BIGDOG466
BIGDOG466
