one terminator or two?
KY JELLY
'65 T-BOLT
one terminator or two? Empty one terminator or two?
Post  cool40 June 1st 2010, 10:42 pm
i'm tryen to decide if i should run one or two ron's terminators on the new build.i have both intakes so i guess the ? is how much better,if any,would two be on a 572 4.625x4.250.all the compression i can get and the heads are the idt a-plus with cnc ports.i'll be 1/8 mile only in a 2500lb door car with a glide and 4.86 gear. Smile
one terminator or two? Empty Re: one terminator or two?
Post  '65 T-BOLT June 1st 2010, 10:45 pm
WOW factor! use 2
'65 T-BOLT
'65 T-BOLT
Post  cool40 June 1st 2010, 10:48 pm
'65 T-BOLT wrote:WOW factor! use 2
the wow factor comes on the time slip! Laughing
Post  richter69 June 1st 2010, 10:53 pm
One, no need for all the extra weight with the manifold etc. The big one flows 2100cfm............. Very Happy
Post  cool40 June 1st 2010, 10:55 pm
richter69 wrote:One, no need for all the extra weight with the manifold etc. The big one flows 2100cfm............. Very Happy
that's what i was thinken.how do you like yours so far?
Post  richter69 June 1st 2010, 10:56 pm
As much as I like the carb's, they aint got nothin' on the terminator..............
All you need now is green oil, NGK plugs and some M5..................you can be a Hero too.......... Laughing
Post  '65 T-BOLT June 1st 2010, 10:59 pm
did not know that the big one flows 2100!
'65 T-BOLT
'65 T-BOLT
Post  richter69 June 1st 2010, 11:04 pm
seen a lot of guys go from one to two and not gain a thing...... a hat mught be different though, but not enough for the hassle.
Post  KY JELLY June 1st 2010, 11:07 pm
The enderle 5" is bigger lol! one is lighter than 2 lol!
one terminator or two? E-2020.50 lol!
KY JELLY
KY JELLY
Post  cool40 June 1st 2010, 11:11 pm
that enderle shit is nice aint it! Very Happy
Post  richter69 June 1st 2010, 11:12 pm
KY JELLY wrote:The enderle 5" is bigger lol! one is lighter than 2 lol!
^^^^baller
Post  Curt June 1st 2010, 11:17 pm
I have a pair of T-2s on mine. 2300cfm each affraid
Post  cool40 June 1st 2010, 11:19 pm
Curt wrote:I have a pair of T-2s on mine. 2300cfm each affraid
DAAAAAMMMMMMMMMMM,cid?
Post  richter69 June 1st 2010, 11:23 pm
one terminator or two? TV10-17-09001-5
Post  Curt June 1st 2010, 11:23 pm
Got a new C-headed 598 going together. Replacing a A-headed 598.
one terminator or two? Newbuild
Post  Curt June 1st 2010, 11:26 pm
one terminator or two? DSCF0585
Post  cool40 June 1st 2010, 11:27 pm
Curt wrote:one terminator or two? DSCF0585
thats what i'm talken bout! Laughing
Post  cool40 June 1st 2010, 11:30 pm
the big reason i'm goen alky is the cooling issues,maybe a A+ tuneup will even get some extra hp. Laughing
Post  cool40 June 1st 2010, 11:35 pm
looked at this on goodvibesracing.com and it aint too bad high,are you runnen this?
Post  Curt June 1st 2010, 11:36 pm
No need to slow the air down having to turn all of those corners. Laughing
Post  cool40 June 1st 2010, 11:43 pm
Curt wrote:No need to slow the air down having to turn all of those corners. Laughing
hell, that's for sure Laughing the air should just fall in with that setup.
Post  c.evans June 2nd 2010, 12:01 am
Curt,
I looked at your .903" Jesel lifters Saturday. Did some drooling and slobbering over them Twisted Evil They are nice Exclamation
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  Curt June 2nd 2010, 12:10 am
Thanks Charlie. Hopefully, it wont be long before they are hid, not to be seen for a long time. Smile
I hope I will get some time off this year to show it off, and to spank some cheby azz. Basketball
Post  racnrick June 2nd 2010, 12:29 am
Here is what Tom from Ron's said when I asked them the same question a few years back, to me it was a double sided answer, some do, some don't Shocked
Re: Toilet Question‏
Sent: Thu 1/15/04 4:00 PM
To: stillfloating@hotmail.com
Rick,
A lot of guys run dual Toilets. Some pick up et and mph and some don't. But duals are even more consistent than a single. An extra throttle body is $380.00.
Thanks,
Tom
racnrick
Post  KY JELLY June 2nd 2010, 8:35 am
Yes , this is what I run. If I was starting from scratch I would get a buzzard catcher and be done with it the only down side is having to buy the tunnel ram. Enderle said the 5 " will flow 4500 cfm , but good vibes advertises it as 2500 ?
I also run a kinsler high speed lean out it picked the car up a tenth at the 1000' mark (let out of it there) ran a 7.64 1000' Very Happy
Charlie is a dealer he can probably fix you up with one
KY JELLY
KY JELLY
