Thread inserts...
feetfirst
Thread inserts...
Had a rocker thread bolt mishap with my A-460 heads.......pulled 4 out on cyl 1 + 2.......have measured the bolts, and realize that 1/2" of thread is not enough..
So, I have the motor back out, and will be installing "keyserts" which is a 5/8 - 11 threaded insert.......is this what most folks use?
Oh, and longer bolts will be used....
feetfirst- Posts : 139
Re: Thread inserts...
look and see if you can get the thin walls keen serts..... just use the regular bolts when done.... you will love them 10000 times better than Heli Coils...
the Coug- Posts : 3055
These are the ones I had in mind?
http://www.fastenal.com/web/search/products/fasteners/thread-repair/keyserts/_/N-gj50juZjue33w&Nty=0
They look the same.... http://alcoafastener.thomasnet.com/category/keenserts-reg-inserts-general-purpose-inserts&bc=1041%7C1042
Have you had your car out yet?
Bill
Bill
billandlori- Posts : 2081
http://www.fastenal.com/web/search/products/fasteners/thread-repair/keyserts/_/N-gj50juZjue33wZjubnsj&Nty=0;jsessionid=497cec1310b3b7a8fc4ddfa87537286eda3742421b6f25239ad789fc79c253e6.e34RbhmQbxiOai0Lb3f0rQjwqQzOnh4
yep but these are the thin wall sets..... take a smaller primary hole....
feetfirst wrote:Had a rocker thread bolt mishap with my A-460 heads.......pulled 4 out on cyl 1 + 2.......have measured the bolts, and realize that 1/2" of thread is not enough..
Bolts? Is this a shaft rocker system?
Same thing happened to my TFS A heads. Replaced all 16 with Timeserts never had a problem since.
http://www.timesert.com/
mico- Posts : 33
Well, its all back together........heading out in a few hours for the weekend to see what happens this time..
Makes a mess when it does happen though....
feetfirst wrote:Well, its all back together........heading out in a few hours for the weekend to see what happens this time..
Good luck! Hope it goes better this time!
Nevs- BBF CONTRIBUTOR
