Dyno Question
+7
Treeyasoon
valleydawg
11 posters
Dyno Question Empty Dyno Question
Post  valleydawg June 6th 2010, 2:54 pm
I have never had one of my engines on the dyno but plan to take the new 598 to the dyno room. I have heard various stories through the years that dyno pulls are very hard on engines. I have heard that one dyno pull is like 3-4 (or fill in the blank) standard passes. Anyone know? If it truly is that hard on the motor I will only make a few pulls. Thanks
valleydawg
valleydawg
Dyno Question Empty Re: Dyno Question
Post  Lem Evans June 6th 2010, 3:30 pm
The dyno is a better envirement than on the track.....I heard all that bs years ago and after seeing engines with dozens of dyno pull I have not seen anything to support those rumors.
Post  richter69 June 6th 2010, 3:32 pm
what Lem said...........
Post  IDT-572 June 6th 2010, 5:19 pm
If that were the case My engine would have never gotten to the track.............. Laughing
Post  schmitty June 6th 2010, 9:42 pm
It took 5 pulls on mine to get it tuned up. Time for a pull isn't that long, less than a fast trip down a drag strip. Very Happy
Post  Treeyasoon June 6th 2010, 9:53 pm
We made 7 pulls on mine...could have made 7 more.
It is some of the best money you can spend.
Treeyasoon
Treeyasoon
Post  the Coug June 6th 2010, 9:56 pm
I feel it is great tool for engine tune... worth every penny spent.....
Post  valleydawg June 7th 2010, 6:40 am
Thanks guys...makes me feel alot better now. I will post the dyno numbers.
valleydawg
valleydawg
Post  Lem Evans June 7th 2010, 7:37 am
Don't get too shy about the number of pulls....it may be the 3rd pull before the rings are completely seated. The power can go up the 1st few pulls w/o any changes .
Post  bbf-falcon June 7th 2010, 8:12 am
This winter I hope to get mine tuned in Smile
Post  rmcomprandy June 7th 2010, 10:26 am
valleydawg wrote:I have never had one of my engines on the dyno but plan to take the new 598 to the dyno room. I have heard various stories through the years that dyno pulls are very hard on engines. I have heard that one dyno pull is like 3-4 (or fill in the blank) standard passes. Anyone know? If it truly is that hard on the motor I will only make a few pulls. Thanks
A LOT has to do with the dyno "DRIVER" and how well he opperates it.
If done with conscienciousness, it is not anywhere near the wear and tear of a track run.
Post  bruno June 7th 2010, 10:34 am
all i know is when i came up to the bash Randy and Mike had i believe a chrysler engine on the dyno and it sure did sound like it loaded down that engine ....... but once it got up on rpm's it ran like a scalded dog
it was a cool experince to see an engine on the dyno, especially having someone like Randy's expertise there and listening to the guru's talk about jetting, carb's, spacer's etc..... your a smart cookie Randy Smile
but i would like to see a BBF on one of those affraid
http://WWW.CKRME.COM
Post  rmcomprandy June 7th 2010, 8:33 pm
bruno wrote:all i know is when i came up to the bash Randy and Mike had i believe a chrysler engine on the dyno and it sure did sound like it loaded down that engine ....... but once it got up on rpm's it ran like a scalded dog
That was a pump gas small block iron headed "Magnum" Chrysler, (a stroker 318 stroked to 361 cubic inches), two plane intake with 4150 carb. (We tried 3 carbs and 4 different spacers with each).
We were pulling it all the way down to 2,400 RPM like an EMC engine and running it up to 6,600 RPM. We made 23 dyno runs that day to find out what it probably needed to be better.
It made 462 pounds of torque and 499 horsepower, (just couldn't get that 500 number). I'm puttin' in bigger intake valves and a different hydraulic flat tappet camshaft and I'll take it down there and try it again, lol.
Tendencies you can learn are not particularly brand oriented ... !
Post  cool40 June 7th 2010, 9:26 pm
if it cant stand a dyno it cant stand the track. Smile
