look what i ordered...pretty cool
AZFairlane
Treeyasoon
meteor545
frank13
Page 1 of 2
Page 1 of 2 • 1, 2
so i got tired of trying to make the wiring in the car nice and neat with that pro look.....so after lots of research i ordered this today:
https://www.youtube.com/watch?v=XAxpsVLJvoo
the best thing was the price! under 300 for everything@
Re: look what i ordered...pretty cool
thats a nice piece i want one!
meteor545- Posts : 151
ARC makes some nice stuff....that panel is way cool...nice find Frank.
I might look into one of those myself....planning on a total re-wire this winter anyway.
Treeyasoon- Posts : 759
they even make a remote switch panel for like 50 bucks that goes into the engine compartment that controls just the fuel,fan,ignition and starter......pretty cool if you are working alone
there stuff is crazy cheap for what it is, and they are great to tlak to.....cant order from them directly, but summit and jegs has it all! should have mine by friday...they say once you get started you can be done wiring the 8 switches to the car in under an hour!
oh, lifetime warranty
summit sells the whole kit with switches and relay panel with wiring harness for under 250
Alright...I got a chance to watch the whole video...that set-up is f-in sick...I will have one before the weekend...
Treeyasoon wrote:Alright...I got a chance to watch the whole video...that set-up is f-in sick...I will have one before the weekend...
dude, it blew me away....its amazing how easy it is to set up
install swich panel
run the comp cable to the relay center you mount in the glovebox(for me)
run the 6g to the batt side of solenoid
run a ground wire to terminal
run a wire to each acces,
start car and drive off!
i am ordering the remote panel and the access panel tomorow....the acces panel has alll the turn sgnals and light and fuses access already built in...3 different sections. always on, key on, switch on
if you want let me know, we can talk about it in the hot rod chat room
Frank,
Good find, that's one of the slickest panels and remote relay systems I've seen.
AZFairlane- BBF CONTRIBUTOR
oh boy, Joe do u like something i found!!!!!!!???????? Kidding bud!
i like how you can change the switches from momentary to maintain.....has a lot of room to grow.....
I will give a full report once i get it in, and start the install.....lots of pics to come!
After some thought....I have a concern.
The ribbon cable plugs into the top of the switch panel via 8 male/female connections....not much to keep it from vibrating loose in a race car situation.
I realize that you could put some kind of strain relief on the cable....and a well-placed cable-tie would hold it but....
It would be cool to see some type of "positive lock" deal on the connection....just some thoughts.....
I'll still own one by the weeekend...lol.
most ribbon cable has positive locks......i dont think i have been this stoked to get something in a while....this is the last step for me to get to the track.....cant wait to test the under an hour install time!
ARC has some nice stuff. I've always looked at that in the catalogs but never paid attention to the functions and flexibility. I'll be picking that up for mine when the time comes. I'd probably get the remote too.
Let us know how it works.
Where did you buy it from? I see Jeg's has it listed for under $240.
jbozzelle- Posts : 3705
SUMMIT.....
AS SOON AS I GET IT, I AM GOING TO CHECK IT OVER THEN ORDER SOME ACCESSORIES FOR IT
I WANT THE TURNSIGNAL/ACCESSORY BANK @60BUCKS
AND THE REMOTE SWITCH PANEL FOR TEH ENGINE BAY AT 50 BUCKS
Definitely a nice product. I have two in my car. Well actually three, a 4 switch remote on the firewall.
doug, anything i need to pay attention to when i start installing this, or is it as easy as it looks?
frank
frank
[quote="Doug Rahn"]Definitely a nice product. I have two in my car. Well actually three, a 4 switch remote on the firewall.
That is a ton of circuits!!
Sure looks nice and clean. Great find Frank, I too will own one of these!! Are you going to use the stock wiring to each circuit or will you run new wire for everything?
Bill
Bill
billandlori- Posts : 2081
frank13 wrote:doug, anything i need to pay attention to when i start installing this, or is it as easy as it looks?
frank
Easy Peasy!
That is so cool and IMO not over priced compared to some of the other stuff on the market.
jones- Posts : 2230
[quote="billandlori"]
Doug!! you have been holding out on us!! Anyh other cool stuff you got??
Doug Rahn wrote:Definitely a nice product. I have two in my car. Well actually three, a 4 switch remote on the firewall.
Bill
jones- Posts : 2230
I HAVE NO ORIGINAL WIRING.....SO....DOUG A QUESTION FOR YA? CAN I RUN THE POSITIVE TO THE FUEL PUMP ALL THE WAY FROM THE RELAY BANK? AEROMOTIVE SAYS TO HAVE THE RELAY AS CLOSE AS POSSIBLE .....
Bill
[quote="frank13"]
It works for me. My relay panel is mounted under the dash on the passenger side.
billandlori wrote:Doug Rahn wrote:Definitely a nice product. I have two in my car. Well actually three, a 4 switch remote on the firewall.
Bill
ok, now to report on this product.......
so i installed it on monday, and was basically done in about 2 hours once i found all my tools! i was able to mount the panel where the ac/heat controls were, the cool part is the panel fits right behind the stock location! looks like it was made to go there.....
the relay panel is sooooooooooooooooooooooo small....amazing the thought that went into it......the mounting tabs on the relay panel make the grounds! but i did add one addtional via a wire....
the computer cable between the switch and relay panels is sick!
everything is nicely lit, and has leds constantly on so you can find the switches in the dark! told they can be on for weeks with hardly any batt draw, but a battery kill switch will shut it off!
only drawback is the fact that i wanted to use ring terminals on the fuel pump which is run as 12 gauge to the pump, and i had to shave down the sides of the ring terminal a little to make it fit, but no biggie, two minutes and that was fixed...
knowing what i know now, i would haev paid two or three times what i paid for it@
good job auto rod controls, good job!
got any pics of it in the dash?
Page 1 of 2 • 1, 2
» This is pretty cool....... At least I think so.....
» pretty cool................
» Interesting and Pretty Cool !
» sbc hemi? pretty cool
Page 1 of 2
