Fox pan
+12
'65 T-BOLT
TeflonDon
Larry Williams
Bsherry
16 posters
Page 3 of 3 Previous  1, 2, 3
Fox pan - Page 3 Empty Re: Fox pan
Post  richter69 June 16th 2010, 10:33 pm
I had a screw in deal with the steel pan, this pad heats much faster than the other did.............surface area.
Little TA31 on the edges and it'll never come off................
Post  Larry Williams June 16th 2010, 11:14 pm
I am just a dumb canook what is ta 31?
Larry Williams
Larry Williams
Post  Nevs June 16th 2010, 11:16 pm
Larry Williams wrote:I am just a dumb canook what is ta 31?
Ford adhesive/sealer
Post  richter69 June 17th 2010, 1:52 pm
Its the selaer for the 7.3 DI, gooooood stuff................... Laughing
Post  curiousgeorge June 26th 2010, 10:53 am
When gluing the pans on do you use the end seals or just the TA 31?
curiousgeorge
Post  Lem Evans June 26th 2010, 10:57 am
Just the silicone.
Post  richter69 June 26th 2010, 11:01 am
Be sure the surfaces are oil free, and dont use to much.
Post  richter69 June 26th 2010, 11:43 am
chassis car pan...............
Fox pan - Page 3 TV10-17-09001-12
Post  Lem Evans June 26th 2010, 11:52 am
A+ pan before install
Fox pan - Page 3 Wet-externanpan002Small
Fox pan - Page 3 Wet-externanpan007Small
Fox pan - Page 3 Wet-externanpan005Small
Fox pan - Page 3 Wet-externanpan006Small
Post  richter69 June 26th 2010, 11:55 am
My return dumps into the section betwen the 2 traps, you can barely see the fitting in the pic on the rh side.
Note the TA31 making sure the heater pad stays in place.
Post  curiousgeorge June 26th 2010, 12:16 pm
Thanks guys cheers
curiousgeorge
Post  Larry Williams June 29th 2010, 9:14 pm
i finally got some ta31. how much did you use attaching the heater pad? just around the edges or ??
note the TA31 making sure the heater pad stays in place. [/quote]
Larry Williams
Larry Williams
Post  richter69 June 29th 2010, 10:23 pm
the ta31 is to seal the edges up, just put a small bead (and I mean small) around the perimeter and smooth with a finger.
Post  Larry Williams June 29th 2010, 10:37 pm
which finger??? I need my middle finger for driving.
Larry Williams
Larry Williams
Post  Lem Evans July 26th 2010, 12:14 pm
BUMP for Larry.
Post  Larry Williams July 26th 2010, 1:22 pm
the ta31 worked fantastic and I never lost a finger. lol ty for letting me know what to use.
Larry Williams
Larry Williams
