carb guru's ....added video
+11
ThndrChkn
D. Sea
Barney
15 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: carb guru's ....added video
Bruno your primary squirter is not doing any thing,,, check to make sure it has a shouldered screw in it... or remove the front squirter and hit the front pump arm and see if it flows fuel out but do it slowly not to shoot it or anything out. some have a ball under the screw. lay a rag over the boosters to keep anything from going down the throttle blades....
if it still doesn't flow. then take the front bowl off and check the gasket and make sure the pump shot hole is not blocked at the gasket....
the Coug- Posts : 3055
What Lem said. But, shouldn't there be at least some fuel coming from the squirters? Mine, even in the worst air, shoots WAY more than that.
Doug...
Doug...
ThndrChkn- Posts : 2216
cletus66 wrote:Man, you ain't gettin' shit outta dem dare squirteraterzzz.
I watched it again, and I agree with myself.
cletus66- Posts : 865
Definately not getting any pump shot....check the accelerator pump diaphram...might have a small rip in it.
Treeyasoon- Posts : 759
Treeyasoon wrote:Definately not getting any pump shot....check the accelerator pump diaphram...might have a small rip in it.
that looks fine !!!
take squirter off, hold finger over hole, attempt to push pump arm down, if it does you got an internal leak .................. gasket or umbrella, if its solid and pump shot still weak you got a blockage someplace.
Bruno are you really trying to figure out to fix your carb, or are you just looking for an excuse to order a new SV1?
Gary
Gary
GTmustang- BBF CONTRIBUTOR
GTmustang wrote:Bruno are you really trying to figure out to fix your carb, or are you just looking for an excuse to order a new SV1?
Gary
nope .... i love my quickfuel ... but i have alwasy been intimidated by carbs , but i have learned alot today on this quick fuel deal .... whats the worst that could happen ....... but we have cleaned everything up and will give everyone an update this evening
Bruno when you blipped the throttle I saw the back squirter work, is that carb setup 1 to 1 linkage? if so why? you do not need a 1 to 1 unless you are tunnelrammed, soft progressive is better for single carb use....
well here is the update .... we are back in business !!!! ... thanks guys for all the help today and thank you Lem for taking your time today and giving me some great advice
here is the updated video
YO, what happened to the newest stile of QFT you had?
Larry T- Posts : 1076
Page 2 of 2 • 1, 2
» Any carb gurus here?
» Question for carb gurus
» carb video
» 7.3 gurus
» C6 gurus please look inside!!!
» carb video
» 7.3 gurus
Page 2 of 2
