Dual wheels on 1993 F350
Will the newer F350 wheels fit on my 1993 F350? Just wondering if they changed anything that would keep a newer set fom fitting my old truck?
Re: Dual wheels on 1993 F350
IDT-572 wrote:Will the newer F350 wheels fit on my 1993 F350? Just wondering if they changed anything that would keep a newer set fom fitting my old truck?
YES SIR !!! the rear is a 8-170 w/ a -13mm os so you can fit like a set of the 03' dually wheels on there no problem ...fronts will work also
bruno wrote:IDT-572 wrote:Will the newer F350 wheels fit on my 1993 F350? Just wondering if they changed anything that would keep a newer set fom fitting my old truck?
If you run up on a set of the 5 spoke factory wheels or something like that, I would like to put something different on my 93. It has simulators on it now.
The OBS (old body style) up to a '97 takes an 8 on 6.5" bolt pattern, the super duty uses an 8 on 170mm, they do not interchange!
AZFairlane- BBF CONTRIBUTOR
AZFairlane wrote:The OBS (old body style) up to a '97 takes an 8 on 6.5" bolt pattern, the super duty uses an 8 on 170mm, they do not interchange!
That sucks..............
thats good to know Joe .... my chart doesnt say anything about SD or not
The best thing about the simulators is that you "can" rotate your tires around...That can be a good thing with a twin I-beam
56Tbird- BBF CONTRIBUTOR
Just to add as an FYI. The 99 and up trucks use a hub centric wheel. The 97 and earlier are lug centric.
» F350 Wheels
» 1993 Mustang 460 Swap Issues
» 1993 F250 4x4, D60, 460/E4OD/1356
» 1993 f250 chassis n stuff
» Mr.Scharf's 1993 Foxbody Notch
