largest tire?
+6
RapidRuss
bigblock t-bird
GTmustang
D's557BBF
10 posters
largest tire?
Anybody know what's the biggest/largest tire I can get under a basic mini tub? also include rim back spacing size??
This is for a 1987 mustang LX hatch
Thanks guys
Thanks guys
D's557BBF- Posts : 1186
Re: largest tire?
29.5 x 10.5w ----- 15 x 12 ---- is the rear end narrowed ????? also lots of rim screws ...
Re: largest tire?
8.8 rear narrowed 1" each side.
Thanks bruno, this was bugging the shit out of me!
What back spacing on the wheels??
also can I use a 15 x 11 wheel? That's what I already have
Re: largest tire?
6.5" of back spacing will get you there !!!!
i wish they had notched my framerail !!!!!! i can only fit a 10.5 on my car
Re: largest tire?
I've got a set of 28x13.5 ET Streets that I'm going to make my Fairmont wagon fit. I have a 8.8 narrowed 1 inch each side, 15x10 wheels with a 71/2 inch back space, full mini tub with notched frame, coil overs, and offset lowers. If my calculations are correct it will work. What do you guys think?
Mike R- Posts : 1381
Re: largest tire?
D': My car is mini tubbed without the frame being notched and I can fit a 28x13.50x15 ET Street (11" wide same as a 28x11.00 ET Drag) on a 12" wheel with 7.5" B/S with a lot of extra room everywhere. I test fit some Hoosier 28x14.50 Quick Time Pro's (12" wide)and they also fit but it was getting a little tight. My rear is also narrowed a total of 2" (1" per side). Hope this helps.
Gary
Gary
GTmustang- BBF CONTRIBUTOR
29.10.5W
With a 9" for a mustang,the help of a BFH I got 29-10.5W on 10"W 6.5BS under 88 T-bird and did not need to cut the iner lip. Bruno these are the wheels I got from you. Steve
bigblock t-bird- Posts : 201
Re: largest tire?
Big D... Ask nos-stang "Greg" he kind of hard to get a hold of at times..you might go thru Zepherbob and ask..But he runs a mini tubbed 93 hatch and hooks very well.. His ride is almost as big of sleeper as Bruno's...his wheels have a nice dish and look great too.. I dont remember off hand how wide his rubber is..But i do knw its a "W" tire... But this is on a DD...and runs a 133mph 1/4.. Just a thought..
RapidRuss- Posts : 334
Re: largest tire?
29.5 x 10.5W on a 12" rim will fit under the mini tub with a little room to spare.
Outlaw5.0- Posts : 122
Re: largest tire?
Outlaw5.0 wrote:29.5 x 10.5W on a 12" rim will fit under the mini tub with a little room to spare.
Is this what you have on your car?? I work in Livonia at Levan and Plymouth can I come check yours out someday??
Re: largest tire?
My car is still at TeamZ, it will run the 315/60/15. I have helped mini tub many mustangs over the years, the 29.5x10.5W will fit with notched frame rails.D's557BBF wrote:Outlaw5.0 wrote:29.5 x 10.5W on a 12" rim will fit under the mini tub with a little room to spare.
Re: largest tire?
I am assuming all this is with stock located control arms with coil overs.am I correct?
waypastcrazy- Posts : 165
Re: largest tire?
Yes you are correct
Re: largest tire?
Denaro: I went with Wolfe Racecraft offset lowers, which give about 1" more clearance between the lower control arm and the tire sidewall if needed. What weight rear springs do you have on your car?
Gary
Gary
Re: largest tire?
Is that pic with the 29.5x10.5w im think about the 89 i just got doing that to. mini tub and stock suspsion.
Northwest outlaw- Posts : 962
Re: largest tire?
Denaro
Thanks for posting those pics. Ive got the same anti roll bar and was wondering how to mount the coilover crossbar. Ive still got my stock gas tank. Will that same setup work with it? Is that a coilover kit or did you piece it together?
Casey
Casey
8liter- Posts : 202
Re: largest tire?
8liters i know with a mini tub and coil overs it is real tight with the stock tank most have to kick the shocks inwards/facing forward at about a 65* . In my eyes thats not a good ideal if you have to run the stock tank i would have cut down/ notched for the room. Hope this helps out. Jason
» tire size back half frame kits tire width on 70 mustang
» Big tire/Small tire.....
» LARGEST DIAMETER LIFTER IN A460 BLOCK
» hey , what's the largest torque you heard of from a 460???
» What tire?
» What tire?
