Need a rear spring recommendation.
Race Ready Fabrications
guys,
Can you ball park me a spring rate for the coil overs on the rear of my car?
87 Mustang hatch. Backhalved, 14x32s, 4 link, BBF and a glide...
jbozzelle- Posts : 3705
Re: Need a rear spring recommendation.
130# ish...........
richter69 wrote:130# ish...........
X2
Race Ready Fabrications- Posts : 619
Thanks.
12 or 14" long?
I'm running a QA1 single adjustable. Recommended ride height is between 13.75 and 14.25. So I'm guessing 14" spring?
12 or 14" long?
jbozzelle wrote:Thanks.
12 or 14" long?
richter69 wrote:14"
With the shocks you said you had and the ride height required they are for a 12" spring. The 13.75 ---14.25 should be from the bolt hole to bolt hole dimension so you have adeqate compression and extension without bottoming out the shock or topping it out.
12" spring Mr Bozelle.
TravisRice- BBF CONTRIBUTOR
Thanks Travis. I'll double check the part number on the shocks next time I go to the garage.
Anyone use the springs from ART? Or is there someplace better? They'll be riding on some single adjustables so I don't need anything fancy, just don't want to waste money on junk.
People call them junky but I have great luck with QA1. Oh and the fastest DR car in the country uses them too.
whatbumper- Posts : 3024
jbozzelle wrote:Thanks Travis. I'll double check the part number on the shocks next time I go to the garage.
John,
I have ran Hypercoils for years and had really good luck with them. Some of the cheaper springs seem to bow in the middle and rub the shock itself after about a year or so of setting or running. Not saying the ART springs are some of them because I don't know for sure 100%.
Travis
Thanks Travis.
I have 80# in mine....ladder bar car.jbozzelle wrote:guys,
Treeyasoon- Posts : 759
we run 110#'s. 12"
120-130lbs sounds like a decent starting point to me. I got 130lb springs for my Maverick & I'm expecting it to be in the 2900-3000lb range. But I also have 80, 100, 110, & 150 pound springs on the shelf to play with.
DILLIGASDAVE- Posts : 2262
» anybody use 200lb rear coilover spring in there foxbody?
» Good DA coil over and spring recommendation
» Need a rear gear ration recommendation...
» Rear Spring Pigtail Location?
» Anybody using the rear spring relocation kit from Crites?
