Friday nite at the races.
nuclearcobra
514Fox87
This our clubs third race of the season and after completely re-doing the fuel system, from putting in a fuel pump relay, to re routing the return line, uping the main line fuel pressure I was excited! Went out for my first time run and the car spit and sputtered to a tune of 1.96 60'. Talk about a swing of emotion! From excited to pissed in 2 seconds flat.
In the pits I found that the floats were off which I had set them at home and they were perfect or I thought they were. Decided to swap out carbs. and put a 1030 AED carb. on borrowed from a friend of nuclearcobra (Bryan). Second run car ran good with a 10.21. Weather was nice but the humidity was up. First round of elim. peddled to 10.23 with the win light. Made it through second and third round and started round robin. I had run a 10.18 on a 10.21 dial in the previous round but my opp. had a .004 red so I ran it out. Dialed a 10.17 for round 4 and off we went. Thought I was a little late on the light but knew it was close. Vega pulled out 2 lengths by the 330 mark but then the big block came to life. Ran him down but he got the win light by .0004 but I ran out with a 10.13. Bryan was at the starting line when my time came up and my son said he wished he had had a camera. He said Bryan was in disbelief. A crate 460 with home ported A429 heads and comp. cam from Lem almost in the nines!!! Yeah baby!!!!
Time to get cert. done and get licensed because it wont be long. Bryan you will spank me with your new SCJ's but I will keep gunning for ya! We may race one day and I want it to be even up!!!
On another note Bryan went to third round with his Mustang II and sitting behind him when he left the line there was a LOT of hood showing over the roof. Stout running little 302 even if it is on steroids! I will let him tell the rest of the story.
514Fox87- Posts : 436
Re: Friday nite at the races.
Sounds like a fun night!! Congrats on getting it sorted out.
Going rounds make it much more enjoyable!!
Bill
Bill
billandlori- Posts : 2081
Yea it was a fun nite Mel and yes my eyes did pop out looking at a 10.13 (where the heck did that come from ) and your right you better get licensed cause with some more fine tuning you got your 9 second car as far as the cobra 2 it was a blast and they say i cant go rounds with the fun spray i like the look on a few of the faces when i pull that big of a wheel stand and i tell them its just a old stock short block 302 from a 86 lsc with a small 292 cam my hightlite of the nite was a 1.403 60' (thanks to a 125 shot and my kaase heads) not bad for a bunch of used parts laying around the garage
nuclearcobra- BBF CONTRIBUTOR
nuclearcobra wrote:Yea it was a fun nite Mel and yes my eyes did pop out looking at a 10.13 (where the heck did that come from ) and your right you better get licensed cause with some more fine tuning you got your 9 second car as far as the cobra 2 it was a blast and they say i cant go rounds with the fun spray i like the look on a few of the faces when i pull that big of a wheel stand and i tell them its just a old stock short block 302 from a 86 lsc with a small 292 cam my hightlite of the nite was a 1.403 60' (thanks to a 125 shot and my kaase heads) not bad for a bunch of used parts laying around the garage
Man, that's a nice launchin ride right there!!
Some times the "misc." engines work damn good!!
Bill
Thanks it was runnin 10.85's that nite.
That car does launch nice,do you still have leaf springs in the back?
Thanks Mark.
Thanks Mark.
Mark Miller- Posts : 1959
Yes leaf springs and south side lift bars
Man sounds like fun, that is so cool.Can't wait until I get mine running again.
67460- Posts : 384
g ood #'s for sure!
514Fox87 wrote:This our clubs third race of the season and after completely re-doing the fuel system, from putting in a fuel pump relay, to re routing the return line, uping the main line fuel pressure I was excited! Went out for my first time run and the car spit and sputtered to a tune of 1.96 60'. Talk about a swing of emotion! From excited to pissed in 2 seconds flat.
Its all in the rear end spool!!!!!! good job guys, proud of ya.
342g- BBF CONTRIBUTOR
The spool helped a bunch. It took almost nine pounds out of the rear! There is more in the car I just need to find it!
Yea like let me put a 100 shot on it for you to try a hundred horse never hurt nobody
nuclearcobra wrote:Yes leaf springs and south side lift bars
What size rear tires and gears are you using?runs good that's for sure.
Later Mark.
MT 28x9 et drags and 430 gears with a PA c4 & ucc 4500 nos converter launchin at 2500 on the footbrake. I weighed it friday nite it was 3065 with me in it with 5 gallons of fuel, Heck Melvyn's car is the same weight or a little lighter and with his carb runnin right he's had 60' times of 1.39 i all motor, like to see what his would 60' with a 125 shot off the line
» Had a panic attack friday nite
» Pic from last friday nite racing at US13 dragway
» Pic's from Goodguy's drags at National Trails last Friday nite
» nite show in toronto
» Thursday nite prerace party
