mixed rods
mixed rods
I bought a 429 out of a junkyard truck recently, and upon tearing it down, discovered it had four D0OE A rods and four D6VE AA rods. From what I've been able to determine these are the better rods to use, but I want to make sure its okay to mix them. The motor looks like it ran for awhile and the crank is okay, but I want to make sure, and seek the advice of BBF pro's. The rebuild will be basically stock.
OahuEli- Posts : 6
Re: mixed rods
Mixing them is OK if the weights are the same OR the crank balance has been appropriately rebalanced.
Re: mixed rods
rmcomprandy wrote:Mixing them is OK if the weights are the same OR the crank balance has been appropriately rebalanced.
Roger that. I gotta remove the pistons to check rod straightness anyway. Do you have any idea of the weight differance as built by Ford?
Just curious.
Looks like I might need to balance the whole recip assy as a safety measure. Oh well, better than ventilating the block I guess. I hear thats not good for 'em! LOL
OahuEli- Posts : 6
» Sold one of my trucks...mixed feelings
» New Grp Rods
» 6.8 scat h beams with arp 2000 bolts
» aluminum rods???
» Crank and rods for 1000hp?
» New Grp Rods
» aluminum rods???
