battery relocation how to fox body
zbob
gents i am a moroonski. i need help describing how to do the job with one of the moroso plastic boxes...car is a early fox with factory duraspark wiring. the disconect switch wiring (kills motor too) confuses me. thanks bobn
zbob- Posts : 271
Re: battery relocation how to fox body
I am hooking up a disconnect too Bob.
From what I have read you need to run a FUSED wire from your alternator out put to the BATT side of the kill switch. Otherwise the alt will keep feeding power and keep the engine going. I have read anywhere from 8ga to 2ga wire.
Bill
Bill
billandlori- Posts : 2081
save you some trouble and install another starter solenoid somewhere in the front of the car (acts like the battery when it was in the front) and run all of you power wires from the engine, gauges, alternator feed wire, and anything else you power. Then run just one power lead to the battery in the rear with the kill switch in that wire. a 2 gauge wire should be enough but if you are doing a fuel injected setup I would run a 0 gauge. then just ground to the frame and/or cage and again if you are running a fuel injected engine I would ground to the frame/cage AND run another ground wire to the front of the car for a floating ground. redundancy!
whatbumper- Posts : 3024
thanks guys i appreciate any info to make it easier! bob
zbob- Posts : 271
In a drag car if it's going to be a conventional lead/acid battery that's used, install it so that the battery's lead plates point front to back.
DILLIGASDAVE- Posts : 2262
thanks dave.....more questions, how or where should i poke the cable through the firewall? with a grommet? or a bulkhead connector?.... it seems i should run it down the passenger side (in side of course along the rocker)
zbob- Posts : 271
Bob, I ran mine on the outside, under the car. If anything rubs through, I don't want those sparks/fire inside the car!! It may be fine inside too, I just chose to go outside. I ran a clamp every 12".
Anywhere it goes through metal you should be OK with a grommet, I used a thick piece of hose zip-tied to the cable.
Hope that helps!!
Bill
Hope that helps!!
Bill
billandlori wrote:Bob, I ran mine on the outside, under the car. If anything rubs through, I don't want those sparks/fire inside the car!! It may be fine inside too, I just chose to go outside. I ran a clamp every 12".
that's what we did.
whatbumper wrote:save you some trouble and install another starter solenoid somewhere in the front of the car (acts like the battery when it was in the front) and run all of you power wires from the engine, gauges, alternator feed wire, and anything else you power. Then run just one power lead to the battery in the rear with the kill switch in that wire. a 2 gauge wire should be enough but if you are doing a fuel injected setup I would run a 0 gauge. then just ground to the frame and/or cage and again if you are running a fuel injected engine I would ground to the frame/cage AND run another ground wire to the front of the car for a floating ground. redundancy!
explaain more please....are you saying to have two starter solenoids....pic please
frank13 wrote:whatbumper wrote:save you some trouble and install another starter solenoid somewhere in the front of the car (acts like the battery when it was in the front) and run all of you power wires from the engine, gauges, alternator feed wire, and anything else you power. Then run just one power lead to the battery in the rear with the kill switch in that wire. a 2 gauge wire should be enough but if you are doing a fuel injected setup I would run a 0 gauge. then just ground to the frame and/or cage and again if you are running a fuel injected engine I would ground to the frame/cage AND run another ground wire to the front of the car for a floating ground. redundancy!
Car is loaded in the trailer right now but when we get it out Friday to race, I will take some pics. Easy to do.
frank i believe the additional solenoid is used to separate the output of the alternator from the original battery terminal. otherwise when you kill the battery the car still runs on with the alternator supplying the juice to the ignition. bobn
zbob- Posts : 271
so just 0 gauge from alt to battery with a solenoid in the middle with a switch powering it? i thought the solenoid could only be used as a momentary switch
not sure of the details frank just the general thinking....maybe relay is better word. hopefully somebody will clarify for us....bobn
zbob- Posts : 271
most disconnect switched have seperate smaller lugs for the alt, just make sure they are of sufficient amperage rating. Any solenoid used for continuous operation....make sure its rated for such usage.
aha says the blind man! now i see! lol thanks! you be the man!
zbob- Posts : 271
frank13 wrote:any pics yet?
sorry, forgot to take them I will tonight. again sorry
whatbumper wrote:frank13 wrote:any pics yet?
Took pics for you but the memory card that I used Saturday night is blank now for some reason. I bought a new one this morning. I am on vacation now so I will try to get pics sometime.
» Oil filter relocation
» trickle chargers
» Oil filter relocation parts
» Battery Cables?
» trickle chargers
» Battery Cables?
