351w question pls
351w question pls Empty 351w question pls
Post  waypastcrazy July 14th 2010, 11:56 am
I have aquired a new 351w scat stroker kit from my brothers divorce.it has an older style crank for 2 piece rear seal. i have several blocks one is a 95 factory roller cam block with 1 piece rear seal. Can the older style crank be modified to install into this newer style block?thx Clyde
waypastcrazy
waypastcrazy
351w question pls Empty Re: 351w question pls
Post  dfree383 July 14th 2010, 12:23 pm
You can on the 302/5.0 stuff not sure on the 351W.......
Post  whatbumper July 14th 2010, 2:12 pm
Most Scat cranks accept both. check the part number on the crank to be sure. Maybe Mark O'Neal will chime in.
Post  waypastcrazy July 14th 2010, 2:32 pm
K thx. I believe it will. I am doing little more research now. Part number is. 9-351-385-59552311wr. Then 07m. 0157. Also has chp 104805. 28oz scribed on it. Thx
waypastcrazy
waypastcrazy
Post  Mark O'Neal July 14th 2010, 4:02 pm
waypastcrazy wrote:I have aquired a new 351w scat stroker kit from my brothers divorce.it has an older style crank for 2 piece rear seal. i have several blocks one is a 95 factory roller cam block with 1 piece rear seal. Can the older style crank be modified to install into this newer style block?thx Clyde
Absolutely.....set it in the block and bolt it down.....
Mark O'Neal
Post  Mark O'Neal July 14th 2010, 4:04 pm
The 104805 is the Sales Order #...also the Balance Card number.
Mark O'Neal
Post  waypastcrazy July 14th 2010, 9:09 pm
Ok sounds good.thz guys I sure appreciate the help. Clyde
waypastcrazy
waypastcrazy
