Danny Bee question
Danny Bee question Empty Danny Bee question
Post  bruno August 24th 2009, 2:24 pm
so how in many runs do i need to change the belt ?
http://WWW.CKRME.COM
Danny Bee question Empty Re: Danny Bee question
Post  c.evans August 24th 2009, 4:36 pm
Nick,
Ask us again in about 2 or 3 years. Meanwhile go racing and don't worry about it!
Uncle Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  IDT-572 August 24th 2009, 5:15 pm
Basically the same material oem belts are made of, good for over 60000 miles. Just try your best to keep oil brake fluid or anything that might attack the rubber away and off of it. They will last a long time.
Post  Doug Rahn August 24th 2009, 6:06 pm
As long as you don't start running sand or mud drags with the Mustang Laughing , a long time.
Post  richter69 August 24th 2009, 6:26 pm
mines got 2 seasons on it, I plan on reusing it for the next build. Oil pump belt has 4 seasons on it, same deal.
Post  Lem Evans August 24th 2009, 7:00 pm
IDT-572 wrote:Basically the same material oem belts are made of, good for over 60000 miles. Just try your best to keep oil brake fluid or anything that might attack the rubber away and off of it. They will last a long time.
No gas , oil or KY Mustang on the belt santa
Post  IDT-572 August 25th 2009, 1:01 am
In other words keep the jelly off the rubber What a Face lol!
Danny Bee question Empty Belted
Post  Wheelie58 September 5th 2009, 10:07 am
bruno wrote:so how in many runs do i need to change the belt ?
The other replies agree with my experience. Kept clean, the belts will last a long...long time.
I have to share an experience (of another racer) from the last race I was at.
There was a guy with a BBC with a Jesel belt drive. He was working on his car and lost a small wrench. Next pass.....he found it. The wrench was found it's way into the belt drive system. wiped the belt out...blew the engine to smithereeeeeens!
So...if you drop a tool...nut ..or bolt...near the front of the engine....find it.
Just a tip.
Thanks,
Keith
Wheelie58
Wheelie58
Danny Bee question Empty A couple more tips for Danny Bee users
Post  Wheelie58 September 5th 2009, 10:15 am
I just thought of something else.
If you remove the belt during maintenance, mark it so you see the rotation...and put it back on the same way it has been running. I am just basing that off of an instinct...no technology.
Also...
Place a slight amount of RTV under the cam bolt washer to keep oil from weeping out through the cam pins and snout. I have seen this causing a nuisance oil leak and re-work.
Later....
Keith
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Post  Lem Evans September 5th 2009, 10:48 am
The best thing to do is not let the oil get to the washer . Put silicone in the pin hole[s] and smear a little on the i.d. the snout hole ....wipe off the excess after the cam hub is installed .
