danny bee ....
fatal addiction
danny bee ....
not sure if i'm allowed to put links to flea-bay but came across this tonight.. my question is will this fit a short snout bbf crank shaft? what is the short snout a 351w?? sorry for the dumb question. thanks eric
http://cgi.ebay.com/ebaymotors/Danny-Bee-Belt-Drive-Kit-429-460-Ford-/270691524149?pt=Race_Car_Parts&hash=item3f0678de35
fatal addiction- Posts : 433
Re: danny bee ....
belt drive for the bb ford has nothing to do with the crank , the dampner hub that slides over the crank is where it matters, depth of the hub is what you look into
-rich
-rich
BOSS 429- Posts : 2372
Re: danny bee ....
I know there are BOSS and BBC snout options, not sure about the fit with the Danny Bee, but I doubt it would be an issue. The balancer or spacer for the appropriate crank is what matters.
schmitty- Posts : 4538
Re: danny bee ....
so the new one from danny bee on flea bay will not work with the boss snout? thanks ericBOSS 429 wrote:belt drive for the bb ford has nothing to do with the crank , the dampner hub that slides over the crank is where it matters, depth of the hub is what you look into
-rich
Re: danny bee ....
fatal addiction wrote:so the new one from danny bee on flea bay will not work with the boss snout? thanks ericBOSS 429 wrote:belt drive for the bb ford has nothing to do with the crank , the dampner hub that slides over the crank is where it matters, depth of the hub is what you look into
-rich
HUH? please re read my post, the danny bee will work with any snout, the d/bee has nothing to do with snout lenght
Re: danny bee ....
thanks rich but i was also refering to snout size. so i take it the 460 and boss snout is the same diamaterBOSS 429 wrote:fatal addiction wrote:so the new one from danny bee on flea bay will not work with the boss snout? thanks ericBOSS 429 wrote:belt drive for the bb ford has nothing to do with the crank , the dampner hub that slides over the crank is where it matters, depth of the hub is what you look into
-rich
Re: danny bee ....
Yes Same Dia. Just the boss one is shorter.
Re: danny bee ....
fatal addiction wrote:thanks rich but i was also refering to snout size. so i take it the 460 and boss snout is the same diamaterBOSS 429 wrote:fatal addiction wrote:so the new one from danny bee on flea bay will not work with the boss snout? thanks ericBOSS 429 wrote:belt drive for the bb ford has nothing to do with the crank , the dampner hub that slides over the crank is where it matters, depth of the hub is what you look into
-rich
yes just as lem also said both the same dia,
i have ran across where people have larger snouts when they custom ordered there cranks,but thats been years ago and i dont see that anymore
Re: danny bee ....
Got to watch the snout dia. sizing, some stuff can be on the high side of the spec and some on the low. meaning some times balancers and parts may require a fitting or hone to fit properly.
Re: danny bee ....
I'm just curious as to if that works with a boss snout how one would use it on a stock snout, being the key ways are different...
138- Posts : 1593
Re: danny bee ....
thanks guys i would just measure it but the crank is at the machine shop. eric
Re: danny bee ....
"The correct dampner could be the main issue with the Boss9 short snout.'
The key for the d. bee cam pulley is 3/16" just like a stock deal . Like I said........the dampner will be the issue......it will need to be keyed 3/16" not the 1/4" the stockers have.
Re: danny bee ....
fatal addiction wrote:thanks guys i would just measure it but the crank is at the machine shop. eric
What you want to look at is the OD of the damper when using a BOSS or 351C snout. With the small block hub it places the damper further back and the OD of the damper gets close to the idler stud. I like to use the ATI SB 6.375 diameter damper.
If you were using a BOSS snout with a chain and stock timing cover the larger 7.25 damper with a SB hub will clear everything just fine.
Gary Blair- Posts : 221
