Ford Motorsport 351 Block
Ford Motorsport 351 Block Empty Ford Motorsport 351 Block
Post  lghting94 July 21st 2010, 1:47 pm
I got this block thru some trading and was going to use it in my lightning but need money so its for sale $1000 OBO
Ford Motorsport casting F5zw-6010-S351-7024 with 302 main journals, 4 bolt splayed mains, 55mm cam tunnel for roller cam bearings, 4.125 bore, has two sleeves from what appears to be a thrown rod incident, Thinniest cyliders from sonic check were the two sleeves was told it can be bored another .030 safely, had block leak tested and all was ok, dry sump block no provision for an oil pump.
What I was told was this block is from a nascar team i have no way to prove or dis-prove this. I can say there has been major oiling modifications done in this block with some type of spray system in it as well as some grouting to reduce windage in the crankcase area.
I DO NOT have a camera to take pics but you are welcome to come look at the block if you are intersested.
Located in Vine Grove KY
lghting94
lghting94
Ford Motorsport 351 Block Empty Re: Ford Motorsport 351 Block
Post  lghting94 July 23rd 2010, 9:03 am
bump
lghting94
lghting94
Post  lghting94 July 27th 2010, 8:18 am
Someone must need/want this!
lghting94
lghting94
Post  lghting94 August 9th 2010, 10:09 am
One more bump
lghting94
lghting94
