C-6 trans forward planet set ?
Does any one know if there is a company that makes a steel forward planetary set with the stock 2.46 gear ratio .
If i can upload some pics I will show you why I need them.
whitefield- Posts : 2244
Re: C-6 trans forward planet set ?
Try OTS, 405 236 4391, ask for Paul...............he's the only guy I'll deal with there......knows his shyt.
I know they offer the rev planet in steel, never asked about the forward for the c6, I know the E4OD set a steel is offered.
The reason I need them is I have a tractor puller who keeps twisting the end off of them where they spline on to the out put shat. The pics. tell a better story !
I will give it a try !
Jon OTS couldn't get it and didn't know of anyone that could. Thanks anyway!
whitefield wrote:Jon OTS couldn't get it and didn't know of anyone that could. Thanks anyway!
Yeah if they cant find one there aint one lol. Only other Choice might be JPT............or if the ratio is no big deal use the 6 pinion 4r100 unit.
» Does adding a wave plate help the forward drum last after trans brake installation
» C-6 front planet burn-ups
» Rebuild kit question
» Anyone using this, C6 Low Drag Gear Set with bearings, wide ratio planet gear sets?
» C4 No forward gears
