Flow Tool ?
Flow Tool ? Empty Flow Tool ?
Post  bigjohn2007 July 26th 2010, 3:00 pm
Can any of you guy show some pic of how you hook your flow tool to one stage system?
bigjohn2007
bigjohn2007
Flow Tool ? Empty Re: Flow Tool ?
Post  studly July 26th 2010, 4:19 pm
just hook to one side of the regulator that feeds the fuel selonoids, if a fogger just unhook one of the fuel lines that go to the selonoids and your finished if plate same thing just unhook fuel line from regulator and hook up flow gauge.
studly
studly
Post  bigjohn2007 July 26th 2010, 5:45 pm
studly wrote:just hook to one side of the regulator that feeds the fuel selonoids, if a fogger just unhook one of the fuel lines that go to the selonoids and your finished if plate same thing just unhook fuel line from regulator and hook up flow gauge.
the other end of the flow gauge you just put in a bottle or hooks to something else
bigjohn2007
bigjohn2007
Post  bruno July 26th 2010, 6:30 pm
i just run mine into a fuel canister ...dont want to waste a drop of c16 Smile
http://WWW.CKRME.COM
Post  bigjohn2007 July 26th 2010, 8:19 pm
bruno wrote:i just run mine into a fuel canister ...dont want to waste a drop of c16 Smile
thanks
bigjohn2007
bigjohn2007
Post  1Bad91 July 26th 2010, 11:34 pm
Whats the easiest way to set one of these up? ANy pictures?
1Bad91
1Bad91
Post  bruno July 27th 2010, 6:11 pm
here is a flow tool that Steve offers
http://www.induction-solutions.com/shop/product_info.php?cPath=17_28&products_id=124
Post  valleydawg July 27th 2010, 7:40 pm
I have one of Steve's flow tools and it works great.
valleydawg
valleydawg
Post  1Bad91 July 27th 2010, 9:45 pm
Nice tool, but any personal set-ups made at home??
1Bad91
1Bad91
Post  bruno July 28th 2010, 6:47 am
i will post some pics of mine this evening
Post  1Bad91 July 31st 2010, 1:29 am
Well I ended up making one....weird things is I set it for 6.5 lbs for N20 but when I hook the line back in to complete the set-up.....the guage reads higher.....alot higher. Sometimes to 13lbs. Not sure what the problem is but I flowed it twice to make sure. Anybody every encounter a problem like this??
1Bad91
1Bad91
Post  bruno July 31st 2010, 5:32 am
1Bad91 wrote:Nice tool, but any personal set-ups made at home??
sorry , i forgot to post up the pic
as far as the guage reading higher its due to the reg is dead heading , on my plate reg. i set up a return line with a small jet in it to bleed off the fuel
Flow Tool ? Picture031
Post  1Bad91 August 1st 2010, 12:59 pm
Thanks bruno....I tried to spray the car last night and Nothing came in the motor. All the NO2 lights were on and purge worked fine, but nothing sprayed. Maybe the solinoids??
1Bad91
1Bad91
Post  bruno August 1st 2010, 1:25 pm
1Bad91 wrote:Thanks bruno....I tried to spray the car last night and Nothing came in the motor. All the NO2 lights were on and purge worked fine, but nothing sprayed. Maybe the solinoids??
before i head out to the track i always do a "dry" ck ..... if you are using a micro switch on the carb make sure the carb is empty and do a full throttle ck while someone else is in the car .... then arm the system and make sure all noids are poping ....
Post  1Bad91 August 1st 2010, 1:31 pm
I'm using a micro switch....I tried it at the track....and heard nothing when I checked. Does the fuel need to be on to or just no2 switch when checking?
1Bad91
1Bad91
Post  bruno August 1st 2010, 1:38 pm
no ...do not turn any fuel on "pump" ..... you are just going thru the motions to ck to make sure the noids are working
Post  1Bad91 August 1st 2010, 3:13 pm
Yep....heard nothing. Is there a way to take them apart and check or just buy new ones and call it a day??
1Bad91
1Bad91
Post  bruno August 1st 2010, 3:17 pm
are you getting 12volts and a good ground at the noids ? when you hit the micro switch is it passing 12 volts thru it to turn on the noids? are you using any relays for the nitrous ?
if everything cks out good and you need some noids give Steve Johnson a call , he is still running his special ..i believe
Post  1Bad91 August 1st 2010, 3:21 pm
bruno wrote:are you getting 12volts and a good ground at the noids ? when you hit the micro switch is it passing 12 volts thru it to turn on the noids? are you using any relays for the nitrous ?
Getting 12 volts......and using a relay. I'm gonna dbl check everything again to make sure but the noids are about 8 yrs old
1Bad91
1Bad91
Post  1Bad91 August 1st 2010, 3:22 pm
I was so pissed....i been waiting to spray this thing and was stuck like a duck at the track...lol
1Bad91
1Bad91
