Cooling system problem
bb429power
Tore
I am trying to help a friend. He has a 427 stroked Windsor and after the car gets warm the top radiator hose colapses after he shuts it off. We have replaced the cap, hose and thermostat. Anyone know why this would happen.
Thanks Tore
Thanks Tore
Tore- Posts : 865
Re: Cooling system problem
Coolant keeps flowing a little bit after the thermostat closes maybe? Thus pulling the coolant out of the hose but not replenishing it. Maybe...I don't know for sure though.
bb429power- Posts : 3129
Air in the system. Does it have a recovery tank or just a puke hose?
dkp
dkp
bosshoss- BBF CONTRIBUTOR
ooooooh yes! That's probably it!bosshoss wrote:Air in the system. Does it have a recovery tank or just a puke hose?
dkp
I have had this happen to me on my old 91 tbird the puke tank hose was stoped up and it could not pull any thing in put a new hose on the problem went away just something to checkbosshoss wrote:Air in the system. Does it have a recovery tank or just a puke hose?
dkp
Puke hose that goes into catch bottle. He races the car.
Tore
dkp
Tore- Posts : 865
Could be just a soft hose but I would be checking to see if the puke hose is plugged and or the cap is working properly. New or not the cap should allow air or water to get pulled back in to the system as it cools. What is the temp when he shuts it off? Leaving the fan/water pump on to cool between rounds?
dkp
dkp
Its a 180 stat, New hose, Its 190 when he shuts it off. Hes still got a stock style waterpump.
Tore- Posts : 865
I was leaving the line this weekend at 160* and it was somewhere around 1/2 mile back to where we were pitted and the temp was 200 or less (engine on gas)
The elderbrock water pump is great for the small block. Had one on my 347 never once had heat problem.
Bigshank- Posts : 150
» cooling system ?
» Cooling System - STREET DRIVEN
» pressurized cooling system??
» Cooling System Air Lock?
» DRAG RACING COOLING SYSTEM
