Opinions On Q16
+9
lghting94
jmayabb
512Fairlane
13 posters
Opinions On Q16 Empty Opinions On Q16
Post  512Fairlane July 28th 2010, 11:38 pm
What's the general consensus on switching to oxygenated VP Q16 vs non-oxygenated? Is there much HP to be gained? I know where I can get a drum cheap from a mud racer who is getting out of the sport. He says he had to jet up several sizes but it made a noticeable difference. Any drag racers that have made the switch out there?
512Fairlane
512Fairlane
Opinions On Q16 Empty Re: Opinions On Q16
Post  whatbumper July 28th 2010, 11:48 pm
Not really a fair comparison but we made close to a 100 more horsepower with our turbo car.
Post  jmayabb July 29th 2010, 8:22 am
We made a pass with our old setup and ran 133 mph in the 1/8. Came back and drained all the fuel out of the tank and put in Q16 and changed the jets and went 136 with no other changes.
I have heard some people say they gained between 25 and 50 hp by switching to Q16. We run Q16 all the time now.
jmayabb
jmayabb
http://www.joesraceparts.com
Post  dfree383 July 29th 2010, 8:37 am
Definetly gains to be had, the stuff is amazing on the dyno, I just can't justify running it on the track bracket racing, as it too expensive. but if you need the edge its extra throttle in your tank.
Post  rmcomprandy July 29th 2010, 10:06 am
There is a reason that NHRA made it an illegal fuel for their STOCK and SUPER STOCK eliminators.
Post  richter69 July 29th 2010, 4:45 pm
Q16 is the bad motherf-cker, what carb are you using?
Post  lghting94 July 29th 2010, 4:50 pm
I switched from sonnoco 112 to vp113 this year on the dyno and gained 18 hp in my little motor so i would guess more on the 116
lghting94
lghting94
Post  dfree383 July 29th 2010, 4:56 pm
lghting94 wrote:I switched from sonnoco 112 to vp113 this year on the dyno and gained 18 hp in my little motor so i would guess more on the 116
its the Q thats important.
Post  lghting94 July 29th 2010, 4:57 pm
The 113 is q or oxiginated (spelling)
lghting94
lghting94
Post  512Fairlane July 29th 2010, 10:23 pm
richter69 wrote:Q16 is the bad motherf-cker, what carb are you using?
I've got a fairly new Holley 8896 1050 Dominator. Is there anything special you have to do with it compared to regular fuel? I've heard you don't want to store it in plastic jugs near sunlight and I saw a few posts on here about condensation in the oil. Is that an issue? How many jet sizes do you typically have to go up?
512Fairlane
512Fairlane
Post  whatbumper July 29th 2010, 10:46 pm
I store mine in metal and plastic jugs with no problems. It has a VERY strong odor and can get to you in a hurry so be careful filling jugs/cell. We were told it would put condensation in the oil but I think our condensation comes from the use of ice water int he block and 50-60 degree inlet temps and it is actually very little or not at all now with the usage of a pretty big vacuum pump. LOL
Ours is EFI so I don't know about jet sizing but we had to add about 15% over C16 BUT we don't use 15% more fuel. The stuff made our setup more efficient. Just a little FYI.
and..it cost a bunch so you guys are right.....not a great choice for bracket racing.
Post  richter69 July 29th 2010, 10:52 pm
If those metering blocks are the cast units and its a 3 circuit............has been some issues with not being able to get enough jet in the deal......the tubes in the passages for the int circuit restrict the flow in the main wells. It might not be an issue, but if upping the jets gets no results then there may be a concern with this. A good set of billet blocks will fix it.
The fumes are not so bad compared to m5............ Laughing
Post  512Fairlane July 29th 2010, 11:54 pm
A friend of mine bought a 55 gallon drum and he doesn't plan to race anymore. I thought I might try some just to experiment with. If its that much more expensive I probably wouldn't use it all the time but I thought if it would get me closer to the 10.0 index I might do some index racing.
512Fairlane
512Fairlane
Post  bbf-falcon July 30th 2010, 8:12 am
Don't let it set in your carb bowls very long periods at a time. The corrosion is fierce.
Post  Lem Evans July 30th 2010, 9:49 am
It's not a good idea to let any style fuel set in a racing carb for long periods of time. Drain and dry for the winter months.
Post  Oakley Motorsports August 2nd 2010, 12:23 am
I keep hearing about what this fuel being corrosive. I have been running it for 2 years and never seen any sign of that. I would really like to hear more about what the circumstances are when this happens. If you leave q16 in your bowls for say 2 weeks It will evaporate. Are we sure people are not having condensation issues with cars setting around. Never seen it leave moisture in the oil either. Could those of you that have had these problems elaborate. I am a VP dealer and also Sponsored by Vp and would like to pass along some of these concerns and problems.
If I can help anyone with questions about this or other vp products fell free to contact me. 270-684-1069 work
Oakley Motorsports
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  bruno August 2nd 2010, 6:03 pm
Oakley Motorsports wrote:I keep hearing about what this fuel being corrosive. I have been running it for 2 years and never seen any sign of that. I would really like to hear more about what the circumstances are when this happens. If you leave q16 in your bowls for say 2 weeks It will evaporate. Are we sure people are not having condensation issues with cars setting around. Never seen it leave moisture in the oil either. Could those of you that have had these problems elaborate. I am a VP dealer and also Sponsored by Vp and would like to pass along some of these concerns and problems.
can you see if they can lower there price for c16 Razz Laughing Laughing
ps i had some problems with corrosion on my deal but it was just condensation from the winter months ..it was not the fuel Wink
http://WWW.CKRME.COM
Post  Lem Evans August 2nd 2010, 6:41 pm
Ask KY Jell what nitro will do to a carb Surprised
Post  richter69 August 2nd 2010, 7:16 pm
Lem Evans wrote:Ask KY Jell what nitro will do to a carb Surprised
which carb? Them alum bowls on the QF carbs look like hell after they have had alky in them.
Post  Lem Evans August 2nd 2010, 7:38 pm
Would you wax your truck with brake fluid?
Post  richter69 August 2nd 2010, 7:51 pm
Lem Evans wrote:Would you wax your truck with brake fluid?
The only thing Fabio waxes is the ass on the wife.......
Post  56Tbird August 2nd 2010, 8:04 pm
It don't count without pics cheers king
56Tbird
56Tbird
Post  bruno August 2nd 2010, 8:06 pm
and it dont count if its a "w" Razz Razz Razz Razz Razz
i kill myself sometimes !!!!! cheers cheers lol!
Post  KY JELLY August 2nd 2010, 8:30 pm
not good lol!
KY JELLY
KY JELLY
Post  richter69 August 2nd 2010, 8:58 pm
As for the "W" thing, just remember what Sir Mix a lot says........ Wink
