head gasket thickness
how much comp. will i loose if i go from .041 to .080 head gaskets...thanks
fatal addiction- Posts : 433
Re: head gasket thickness
fatal addiction wrote:how much comp. will i loose if i go from .041 to .080 head gaskets...thanks
http://www.diamondracing.net/cocalc.htm
calculate it out and see
the Coug- Posts : 3055
thanks man... i calculated it out and it came up with 16.88 w/.040 14.92 w/ the .080 does this sound right? the only thing i'm unsure of the my c- heads chamber volume...thanks again
what diameter did you use for those head gaskets?
their 4.630the Coug wrote:what diameter did you use for those head gaskets?
» Head Gasket ?
» Need head gaskets (Lem?)
» when to use an mls head gasket.
» Head gasket
» thinnest head gasket
» Head gasket
