External oil pump -- Converting a conventional wet sump oil pan
+8
CP598
CDMBill
Wheelie58
96Mustang460cid
12 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: External oil pump -- Converting a conventional wet sump oil pan
Just wish to add that we have started to offer our Free-Flow pickup kit. This kit includes the pickup strainer box, the tubing (you bend it to your desired shape) and a pickup tube brace and pump flange (these kits are meant to be used with internal oil pump).69bluehotrod wrote:
Lem, is this piece something you have available to buy? if so, does it accecpt #16 fitting? & hw much $.
thanks
Terry
Basically, the Free-Flow pickup kit includes the parts shown in the picture below but without the oil pump or pump drive.
They make up an oil pump pickup that would normally look something like this (or whatever suits your build):
You can also use parts in this kit to fab your external line...in fact I'm using these parts on an external line F700 pan right now. We can sell you just the raw parts you need. We are currently doing a run of three dozen of the Free-Flow kits to keep up with demand.
Call or PM if interested,
Paul
Page 2 of 2 • 1, 2
» External wet sump oil pump
» Oil Pump Pick Up for Front Sump Pan and Kaase Pump
» Which External Wet Sump Pan do I need?
» external wet sump set up
Page 2 of 2
