Tunnel wedge intake
+15
DJOHAGIN
Diggindeeper
dadof384k
plovett
LivermoreDave
nuclearcobra
57custom
19 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: Tunnel wedge intake
[/quote]
What good is an intake that flows 470 when your heads won't flow anywhere close to it?
Randy[/quote]
Future growth
G-
G-Code- Posts : 193
Randy[/quote]
Future growth
G- [/quote]
Show me any FE thats head will flow any where close......
None the biggest valve that can fit in any of those heads is 2.23 comfortably....
the Coug- Posts : 3055
Future growth
G- [/quote]
Randy[/quote]Tunnel Port Stuff used a 2.25.........
yes Dave and 90% have cracked cylinders between the intake and exhaust seats.... almost everyone I have seen has....and yes the High risers had 2.250 also but almost everyone has cracked head between the seats ....
I was only slightly being a smart ass, but since you asked, here you go:
If I recall correctly I was told there's a guy who get's raw edelbrock castings and get's mid 400's out of them.
I actually meant to hit a after my last post but didn't edit it.
G-
G-Code- Posts : 193
That aint no production FE head, that a Tunnel Wedge intake is going to go on.........Might as well be a Cleveland.......
For Reference SOHC heads will get into the low 400's with good porting.
you can get a repop TP from Dove, but you'll be lucky if the head bolt holes are in the right spot
for reference Garrett Machine makes an adaptor that goes from FE to a cleveland style intake for those who care.......
Diggindeeper- Posts : 800
It's a fallacy that your intake and cylinder head should flow the same on the flow bench. A flowbench doesn't accurately simulate what happens in your cylinder head when the engine is running. That's fine as the flow numbers you get are just a measure for comparison. When you flow an intake manifold the flowbench again doesn't accurately simulate what happens in your intake and furthermore it's inaccurate in different ways. So, just because your heads flow 320 cfm on a flowbench doesn't necessarily mean your intake should flow 320 cfm, too. Don't get mesmerized by solely by numbers.
All that said, I would say, and this is a guess and a generalization, that ideally your intake manifold as flowed on a bench "should" flow about 25-30% higher than your cylinder heads flow on a flow bench.
And I believe even when the intake flow to cylinder head flow ratio exceeds that, the engine will stay make more power, assuming the intake CSA and/or plenum volume is not too big.
paulie
paulie
Last edited by plovett on August 17th 2010, 5:32 pm; edited 2 times in total (Reason for editing : spelling)
plovett- Posts : 65
I don't want to become part of this pissing contest, but Jeff Colvert has the Edelbrock FE "P" casting flowing well over 400 CFM.
Dave.
P.S. How are you doing Todd?
Dave.
LivermoreDave- Posts : 972
Here's the big question. What would this manifold do that any other manifold we have won't do?
schmitty- Posts : 4538
schmitty wrote:Here's the big question. What would this manifold do that any other manifold we have won't do?
LOOK trick under the hood of a street/cruising car, LOL.
Blue Thunder makes a "Tunnel Wedge" design intake for the 385 series engine, albeit, you have to use Boss heads to use it.
Picture: http://www.460ford.com/forum/showthread.php?t=119686 Scoll down.
How much work would it take to adapt that intake to a set of CJ-style heads?
Dave
Dave
DJOHAGIN- Posts : 91
Dave,
The interface angle between the wedge heads and intake manifold is a fairly standard 45*. Between the Boss heads and intake manifolds it is a 30* angle I believe. One time years ago I was able to get an unmachined Indy Cylinder Head 440-1 intake manifold from Russ Flagle, and then adapt it to something else. In regards to this 2 X 4 tunnel wedge idea, the best way to get there would be to get a raw unmachined Boss intake manifold from Art Francis at Blue Thunder, and I still wouldn't guarantee that it could be done.
Hope this helps,
Charlie Evans
Hope this helps,
Charlie Evans
c.evans- BBF VENDOR SPONSOR
rmcomprandy wrote:schmitty wrote:Here's the big question. What would this manifold do that any other manifold we have won't do?
I suppose this doesn't apply to the 385 series guys 'cause the manifold in non-existant, but I got mine cheaper than a Victor FE, it flows more out of the box, I'll have better hood clearance, and two good 3310's cost me about $200. But most importantly I don't want to be in the "me, too!" crowd with a stroker motor, solid roller cam, and Victor intake.
JMO,
paulie
plovett- Posts : 65
My Grandpa had an FE.............
Question is.....is it a better manifold and/or head? The stock car deals.....2V and 390 4V engines it'd look like it would not matter about additional flow. Facts are that better stuff runs better. A good design will make more power and a good design seems to also flow better.
I would say that the Victor with a Dominator will be roughly equal in potential to a Tunnel Wedge with with two 4150's. On an FE that is. So there's probably nothing to be gained in making a 385 series version. But for Randy to say the Tunnel Wedge is for looking cool while cruising the fairgrounds is just plain ignorant.
And by the way I totally get that any common 385 series engine has more potential than any common FE engine.
paulie
paulie
plovett- Posts : 65
plovett wrote:I would say that the Victor with a Dominator will be roughly equal in potential to a Tunnel Wedge with with two 4150's. On an FE that is. So there's probably nothing to be gained in making a 385 series version. But for Randy to say the Tunnel Wedge is for looking cool while cruising the fairgrounds is just plain ignorant.
paulie
I think you should read and understand the jist of this whole thread. The FE Tunnel Wedge is not in question here. You seem to be SOoooo defensive that you can't see or read straight.
Then YOU should tell me and everybody else here what would be the purpose of the production of a "Tunnel Wedge Style" intake made for a 385 engine. THAT was the question and it said NOTHING about that manifold on an FE.
It is evident that you wish to defend the Tunnel Wedge and calling people names which questions their knowledge on the subject is your main way to try to discredit them.
I have probably done more work and more dyno testing with an FE Tunnel Wedge along with the actual Tunnel Port manifolds than you must realize - IGNORANT; I think you should get a dictionary and look up the meaning of the word.
The ONLY purpose for having one MADE FOR A 385 ENGINE is for the LOOK it would provide; other manifolds available would surely OUTPOWER it.
This has absolutely NOTHING to do with that intake manifold on an FE engine.
EDIT: AND, I never said anything about fairgrounds ... you also seem to like to put words into people's mouths when it suits your argument.
rmcomprandy wrote:plovett wrote:I would say that the Victor with a Dominator will be roughly equal in potential to a Tunnel Wedge with with two 4150's. On an FE that is. So there's probably nothing to be gained in making a 385 series version. But for Randy to say the Tunnel Wedge is for looking cool while cruising the fairgrounds is just plain ignorant.
paulie
That was fun. Thanks for explaining yourself more clearly. Sorry I said "fairgrounds". My mistake. LOL!
paulie
plovett- Posts : 65
Cool Factory Yes..... Keep in mind the tunnel wedge stuff was build PD (Pre-Dominator)...... Only way to get enough air into a motor was a 2x4 set-up.
Let me make it a little more clear. I apologize to you, Randy.
It seems we have both rubbed each other the wrong way.
paulie
paulie
plovett- Posts : 65
dfree383 wrote:Cool Factory Yes..... Keep in mind the tunnel wedge stuff was build PD (Pre-Dominator)...... Only way to get enough air into a motor was a 2x4 set-up.
Absolutely. There's definitely a few more ways to get there now. There's at least 3, maybe 4 completely different manifold/carb designs that could get me into the hp range I'd like to be in.
paulie
plovett- Posts : 65
2x4 single plane
Last edited by JBR-3 on February 22nd 2020, 1:35 am; edited 1 time in total (Reason for editing : .)
JBR-3- Posts : 266
Yes in theory, equal legnth runners would be desireable, but on the same subject, unequal length runners tune in the middle or equalize so to speak.
plovett wrote:Let me make it a little more clear. I apologize to you, Randy.
paulie
No need for an appology ... just realize that the FE engine and that already available intake had nothing to do with any of my comments.
They were all about producing a Tunnel Wedge Style intake for a 385 engine.
» Tunnel ram intake
» new never used trickflow a460 tunnel ram single carb top plate ....looking to trade
» TFS tunnel ram intake
» FS: TFS tunnel ram intake and pushrods
» when does a tunnel ram intake become helpful
Page 2 of 3
