Chaining a motor down
Outside of using motor plates, what have you guy's used to chain a motor down to lessen the amount of movement? I was thinking braided cable with I bolts with a turn buckle.
Any pics would be cool.
Dave
Dave
NO FAIR- Posts : 138
Re: Chaining a motor down
A piece of tubing with heim joints in each end has always seemed to be a good choice for travel limiters....
Treeyasoon- Posts : 759
torque link
429 in fairlane
Last edited by Bigshank on August 13th 2010, 5:35 am; edited 1 time in total (Reason for editing : add pic)
Bigshank- Posts : 150
Here is a pic from years ago. My 69 Mustang with a stroker sbf. I used a turnbuckle, eye bolt, j-bolt and chain. I also used a piece of alternator spacer to space it away from the head so it would line up with an existing hole on the chassis (sway bar mount hole). The car still had rubber motor mounts and with the tall intake, spacer and breather the engine would rock over far enough for the breather to hit the hood. This setup solved it. Wasn't too tight, just enough to keep it from moving, but the rubber motor mounts could still damper the vibrations..
» Motor plate or motor mounts?
» Witch Motor Would Be The Best Motor 557 0r 547 & Why ? ? ?
» Crane Gold Rockers, Probe stud girdles and Comp pushrods.
» 466 FOR SALE, NEW FRESH FOX BODY SET UP
» sold
» sold
