Witch Motor Would Be The Best Motor 557 0r 547 & Why ? ? ?
GFPRACING
I May Be Asking This Wrong .
If So I am Sorry .
But .
I wanted to Compare these 2 Motors .
I wanted to Start Out With a New Block .
Stay With The Smallest Bore I Could .
{{ Every Else Being the Same }}
Naturally Aspireted
No Nos .
No Turbo's . { Forced Induction }
No Alcohol
{ Race Gas / Fuel Only }
2 = QUICK FUEL { #FX-4712-2 } 1250cfm Dominators -
Trick flow Tunnel Ram Ported to Each Set of Heads !.
Jesel Custom Rocker
Diamond 15.to 1 Pistons { Dome Custom Made to they Heads } ! .
Oliver Steel Rods
Bryant Light Weight billet Crank .
Roller Cam Bearings .
Danny Bee Belt Drive
Dry Sump Oil Sys .
Vac Pump .
ATI Balancer .
Jesel Front Drive Kit With Distributer .
{{ 557 Motor ! . }}
The Keith A460 Interceptor Head's { With Smaller Valves to Work on a the Bore } ! .
0r .
Best A460 Head's Ported Made on the 557 ! ! ! .
Cam Size to Motor's Need's ! .
A460 Block .
4.500 Stroke .
6.800 Rods .
4.44 Bore .
{{ 547 Motor ! . }}
Eliminator Premier block
4.300 Stroke .
7.00 Rods .
4.500 Bore .
This would Be Going in .
1970 Ford Pro Stock Maverick .
All Chrome Molly 25.1 E . Cert to 6.00 1/4
Strut , 4 link .
Full Chassis Car 2300 lbs with Driver .
Power Glide .
Gear Ratio Needed ? .
1/8 Mile Racing only
If So I am Sorry .
But .
Naturally Aspireted
No Nos .
No Alcohol
Jesel Custom Rocker
Oliver Steel Rods
Dry Sump Oil Sys .
Vac Pump .
ATI Balancer .
{{ 557 Motor ! . }}
0r .
A460 Block .
4.500 Stroke .
6.800 Rods .
4.44 Bore .
{{ 547 Motor ! . }}
4.300 Stroke .
7.00 Rods .
4.500 Bore .
Strut , 4 link .
Power Glide .
GFPRACING- Posts : 38
Re: Witch Motor Would Be The Best Motor 557 0r 547 & Why ? ? ?
For the benefit of the intake valve flow I'd use a bigger bore.
4.560 or bigger x 4.3 or 4.560" or bigger x 4.5 would make more sense.
Is there some kind of CID rule?
cletus66- Posts : 865
Lem Evans wrote:For the benefit of the intake valve flow I'd use a bigger bore.
4.600" x 4.300" is where I would go for this application with that 2.500" intake valve; unless as has been said, there is some kind of cubic inch to weight rule.
In that case ... 4.600" x 4.150" is 551 cubic inches.
Bigger is better.... I’d be doing a 598 or 632
Was Wanting to Buy a New Block .
Start With the Smallest Bore ! .
That .
That Block Could Be Use With ! .
That .
Maybe.
I Ask it Wrong .
If so I am Sorry .
I said .
0r .
Want to Ask is
Keith A460 Head Interceptor { Valve Sized to Fit the Bore of Each Motor } ! .
Dont Get Stuck on a 2.5 Valve .
So .
More Or Less
The Keith A460 Head Interceptor With 2.5 Valve Used on the 547 ! .
The Keith A460 Head Interceptor With Smaller Valves on The 557 ! .
0r .
Best A Head Ported Get the Job Done ! ! ! .
I Ask it Wrong .
If so I am Sorry .
I said .
0r .
Want to Ask is
So .
More Or Less
0r .
Why would you take a head like the Interceptor and put smaller valves in it?
Big heads require big valves which need big bore diameters which can/should produce big power!!!!
wickettoby1- Posts : 352
wickettoby1 wrote:Why would you take a head like the Interceptor and put smaller valves in it?
very simple he wants everything for free or as close to it as possible, He is on government assistance can't afford any thing. He is out to put it to someone step up and get yours he has been on every forum under different names, when he Pi$$es everyone off he disappears for a short time then comes back with a slightly different name. Then he starts asking all the same Questions over again. So until someone tells Him Oh yes everything you are doing is the greatest you know it all he will keep Trolling.....
There is an old saying if it looks like Chit, smells like Chit and taste like Chit it's pretty safe to say it's Chit
Up Yours Cartwright
Yours truly Albert
Albert Clark- Posts : 72
Buy a new set of pro comp heads and build a 503.. best option cause why......... Pay a engine builder. If you are going to use Keith's head pay him for his knowledge..... WUT?
460pulling- Posts : 249
» Witch is a better head.
» The Witch is Dead
» Motor plate or motor mounts?
» Engine advice
» 466 FOR SALE, NEW FRESH FOX BODY SET UP
» The Witch is Dead
» Engine advice
