The Witch is Dead
+13
Moodyblues
56Tbird
dr's wife racing
342g
BigDave65
crittersf1
manofmerc
Wheelie58
17 posters
The Witch is Dead
I regret to report that my trusty sidekick.... the good old 605 is dead.
Yesterday, on a time run about 4.5 seconds in to the pass, the engine made a bad noise and shut off. I pulled over near the wall and coasted to the first turn-off. The safety crew reported no liquids under the car, and saw no smoke fumes, or fire. They asked what happened, and I told them "something very very bad". After the car was towed to my trailer, I noticed water running out of the engine diaper.
It appears that the #7 wristpin broke, beat up the piston, knocked out the cylinder wall and then wedged the rod between the crank and the bottom of the cylinder.
It looks like the entire short block will need to be replaced.
They were Trend pins, but I do not have the entire specs yet. This weekend, it would have put is near the 600 run mark. The engine was happy when it died. It was doing what it really enjoyed.
So....the neglected 514 will head for the dyno for a little tune-up and go back in to service.
I guess I will order a new block in the morning and get the ball rolling on a replacement.
P.S. the DRE diaper....like it or not...did a great job. Not a drop on the track and the pan has 2 or 3 holes.
Keith
Keith
Re: The Witch is Dead
Ouch! Sorry to here that.
cue Six Mil Man/Bionic Man music.......rebuild.....bigger.....faster......stronger
Yeah....better wristpins for sure! and maybe a few more CFMs....David Cole wrote:Ouch! Sorry to here that.
Thanks,
Keith
"We have the Technology"......
Never know, Might be able to save something out of the old motor. Blocks can be sleeved and filled.
Looking for you
Keith I was looking for you But i didnt find you sorry about your engine .You will be back I didnt have the greatest weekend either but all is good some changes are coming for my combo .Doug
manofmerc- BBF CONTRIBUTOR
600 runs is a very good life-span! That power-plant doesn't owe you a thing
crittersf1- Posts : 521
Hate to hear you blowed up, glad you had the diaper on it or it could have been much worse!
BigDave65- Posts : 567
Hate too hear this Keith. We all know you will be back better than ever.
Ouch! That'll put a dent in the retirement funds. Sorry to hear about the carnage.
Curt- Posts : 2791
Sorry Keith, you will come back, stronger, and faster, take a little break, and then get back to work.
342g- BBF CONTRIBUTOR
Sorry for the bad luck,been there done that.I know how expensive it is to have a total loss.
I feel for you Keith! I know the next one will be even better! Good luck my friend.
56Tbird- BBF CONTRIBUTOR
Seems the pin failed due to methanol.
The effect of a sulfur source on the performance and metal retention of methanol-fed upflow anaerobic sludge bed (UASB) reactors was investigated. For this purpose, two UASB reactors were operated with cobalt preloaded granular sludge (1 mM CoCl2; 30 °C; 24 h) at an organic loading rate (OLR) of 5 g COD·L reactor−1·d−1. One UASB reactor (R1) was operated without a sulfur source in the influent during the first 37 days. In this period the methanol conversion to methane remained very poor, apparently due to the absence of a sulfur source, because once cysteine, a sulfur-containing amino acid, was added to the influent of R1 (day 37) a full conversion of methanol to methane occurred within 6 days. The second reactor (R2) was operated with sulfate (0.41 mM) in the influent during the first 86 days of operation, during which no limitation in the methanol conversion to methane manifested. Cobalt washed out from the sludge at similar rates in both reactors. The leaching of cobalt occurred at two distinct rates, first at a high rate of 22 μg·g TSS−1·d−1, which proceeded mainly from the exchangeable and carbonate fraction and later at a relatively slow rate of 9 μg·g TSS−1·d−1 from the organic/sulfide fraction. This study showed that the supply of the sulfur source l-cysteine has a pronounced positive effect on the methanogenic activity and the retention of metals such as iron, zinc and molybdenum.
Lem Evans wrote:Seems the pin failed due to methanol.
I agree with this 100%, I think.
I agree fully.
Methanol makes horsepower, which in turn made the pin fail.
Thanks guys.
If I find interesting things as I disassemble the engine, I will share the info if it may help others.
Keith
Thanks guys.
Keith
BAM!
Lem Evans wrote:"methanogenic activity"
Is that what Bad Finger Bob was checking for in that pic of him and JY?
schmitty- Posts : 4538
sorry about you bad luck.build it stronger and faster!
This is the most important thing. I'm glad to hear it went peacefully....This will give you closure. Good luck with the new mill.Wheelie58 wrote:The engine was happy when it died. It was doing what it really enjoyed.
Treeyasoon- Posts : 759
Sorry.
Sorry about your Engine Keith. Hope you still have the A-460 block you were trying to sell to get started on a new engine. That power plant sure paid it's way for you, several Wally's later and multiple wins this year alone. Good luck on a new build.
Kerry
Kerry
knrclark- BBF CONTRIBUTOR
» Witch is a better head.
» Dead cyl's on BBF
» Is Pro-Street Dead?
» Back from the dead...
» Top dead center
» Dead cyl's on BBF
» Top dead center
