Witch is a better head.
Witch is a better head. Empty Witch is a better head.
Post  res0rli9 April 26th 2016, 7:41 pm
The Yates D3 cylinder heads or Kaase's P-38
witch one will give the most hp & trq. for racing.
Witch is a better head. Empty Re: Witch is a better head.
Post  rmcomprandy April 26th 2016, 9:12 pm
res0rli9 wrote:The Yates D3 cylinder heads or Kaase's P-38
witch one with give the most hp & trq. for racing.
The Yates D3 of course.
The ports are raised a bunch on the D3 and it uses Cleveland rocker arm geometry; the P-38 has O.E.M. production location ports.
Post  FalconEh April 26th 2016, 9:46 pm
^^^^^^^This^^^^^^^^ A few things to be aware of... pistons, and there are 9.2 and 9.5 deck intakes for them, you can get spacers but be aware of what you are buying, further headers with a raised port design will change, however they will enjoy RPM and NOS is not a problem.Wink
Post  res0rli9 April 26th 2016, 9:59 pm
Thanks guys
Post  bbf-falcon May 8th 2016, 1:36 am
Randy,i've heard the Yates sbf head referred to as a JR. version of the C460. Is this true?
Post  rmcomprandy May 8th 2016, 10:58 am
bbf-falcon wrote:Randy,i've heard the Yates sbf head referred to as a JR. version of the C460. Is this true?
The other way around ... the C460 was designed around the original Yates NASCAR heads.
Post  bbf-falcon May 8th 2016, 10:31 pm
Cool
Post  turbo2256b May 9th 2016, 10:36 am
Flow tested a Yates head a few years back. Figure they were not fully ported but the big thing was flowing at 360 CFM they were had to be the quietest head I HAVE EVER FLOW TESTED.
turbo2256b
