Manual Automatic Newb Question
Looking for advice, opininions etc, on what to expect or "how" to drive a manual C6 on the street. Is there anything I should know?
Car should be back on the road in a day or two.
Car is a 1970 Torino GT, BF Evans 572, pump gas STREET engine, rollerized C6 w/ reverse pattern manual VB. (and ultimate converter concepts custom torque converter)
Shane
Shane
TorinoGT- Posts : 174
Re: Manual Automatic Newb Question
have a good shifter cuz your gona be useing it a lot.i had one years ago until i found out it would shift just as hard without being manual shift but it was a forward shift pat.if it shifts like mine did you need to have a spare ujoint with you at all times.
If its a full manual you have to shift, its not gonna do it on its own.
nuclearcobra- BBF CONTRIBUTOR
I have a good shifter, a winters sidewinder... had a very thick cable (much thicker than B&M or Hurst stuff)...
ill have to make sure I have u joints on hand... and obviously a drive shaft loop sooner than later then!
Shane
Shane
I don't get the point of the manual vb. I thought it was to make it shift harder, I guess not. I've never had it shift for me when I went all the way to 1st and manually shifted up.
bb429power- Posts : 3129
A true *manual* valve body has NO automatic shifting capability. so its not really about shifting hard per se, but because the new engine I have doesnt really make enough vacuum to operate an auto trans, I went full manual.
shift firmness on an auto can be changed via your typical auto valve body with "shift kits"
Shane
Shane
» Lobe seperation - Manual vs Automatic
» HELP WITH SHIFT KITS
» Question regarding SFI bellhousing for auto transmission, and Automatic Transmission Flexplate Shield
» c4... full manual reverse tran brake question.
» New Performance Automatic PA26445 - Performance Automatic Multi Fit Block Plate
