oil psi drop???
oil psi drop???
What would cause the oil pressure to drop about 15 psi? I was tunning on my carbs an looked down and saw about 45 or a little less. I shut the car off and then started it up then the pressure went back to 60 psi. I reved it a few and it starded to drop again. I don't think the oil would thin out that much. It's always keep 60 psi when it was hot. Any ideas? If it was the pump how would it still work if it was broken?
Re: oil psi drop???
If you got a crack in your pick-up tube or the mounting gasket got weak and allowed it to suck air. That could be one culprit. Another could be bearings starting to go bad. Thats how I found I had bad bearings. Start it up and it had 60 psi. As she warmed up, it would just keep dropping, all the way down to 7-10 psi. Pulled the motor and had 4 trashed rod bearings, and everything else wasn't much better.
jonboyusmc- Posts : 71
Re: oil psi drop???
I think I might have found my problem. I let it sit and cool off a while and went back to start it. 60 psi all the way. Reved it and it never droped. I think when I was screwing with the carbs I flooded it bad and loaded bad with gas. The gas could have separated since it cooled. Don't know. I will drain it, flush it and check tomorrow after work. I guess I will start there.
Re: oil psi drop???
Thanks, me to. It's to close to NMRA for this.
» C6 RPM Drop
» RPM drop
» 533 BBF for sale Albany KY 42602
» Demon dominator and c460 cast Motorsport intake
» Lunati 4.5 stroke crank $500
» RPM drop
