Crank trigger question
+11
jc10000rpm
badnotch
Wheelie58
15 posters
Crank trigger question Empty Crank trigger question
Post  TravisRice August 29th 2010, 7:12 am
I have a couple of crank trigger setups for a BBF. I also have enough stuff accumulated here to build a decent 532 iron head pump gas engine that was originally destined for my truck. Here is the question. Can you run a crank trigger deal with a vacuum advance distributor ?? I know ford used trigger setups on some of thier older 80's police car windsors but for the life of me can't remember if they had a vacuum advance setup on the distributor. I have everything here, it is all paid for, if I can use it I'll keep it and if not I'll put it on the auction block. Planning on thining down some of my spare parts that I will probably never need 2 or 3 extras, yet save enough stuff to complete the 532 and upgrade the 557 also.
Travis
Crank trigger question Empty Distributor
Post  Wheelie58 August 29th 2010, 7:56 am
Travis,
You can make a crank trigger distributor out of just about any distributor that you wish.
Just take it apart and weld the mechanical advance mechanism solid, and put it back together without any of the pickup coil, breaker plate or anything else inside. You just need a housing, shaft and a place to stick the rotor. You could leave the vacuum advance diaphragm housing on there to fill the hole and fool your buddies. If you take it off, you will need to make a little square piece to locate the cap (or cap adapter) since the vacuum advance has the cap locator lug, built-in.
Your advance curve, if any, will be determined by the ignition box or timing control computer that you choose.
The MSD timing computers work nicely, for a reasonable price. They feature a start retard and a built-in timing advance curve.
I hope this helps.
Thanks,
Keith
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Crank trigger question Empty Re: Crank trigger question
Post  badnotch August 29th 2010, 8:06 am
i just bought a 351 crank trigger dizzy that all i have to do is change the gear to a BBF bronze gear and im done Smile something that no one willing to share on here just so you know
badnotch
badnotch
http://www.gnlmotorsports.com
Post  Doug Rahn August 29th 2010, 8:20 am
Post  jc10000rpm August 29th 2010, 8:37 am
just use the 2 wires from your crank trigger instead of your pick-up coil in the dist. Disconnect the vacuum hose to keep the breaker plate held in one position. Mech. adv will work as usual or spot weld to disable it. Use what ever ign. module or box you want, most should be able to use the signal from your crank trigger with no problem
jc10000rpm
Post  badnotch August 29th 2010, 8:51 am
didnt know until couple days ago - thanks saves me alot of trouble
badnotch
badnotch
Post  TravisRice August 29th 2010, 10:38 am
Ok, let me rephrase this. Can any sort of avdance system be used in conjuction with a crank trigger ?? Being this is my pump gas streetable engine, I would assume that it would need to work to put a curve in the timing so that it would be friendly with pump gas. (Mechanical or Vacuum for that matter)
Post  Curt August 29th 2010, 10:47 am
Travis, the great thing about a crank trigger is stable timing that doesnt fluctuate. The digital boxes would allow you to ramp timing in and out at different rpm's. Or, I think the 7531 might even allow more timing adjustments as it is not legal due to being able to add slew rates to the timing.
The trigger would not work well without locking down the dizzy on the distributor. In fact it may be disastrous bom
Post  Wheelie58 August 29th 2010, 10:47 am
TravisRice wrote:Ok, let me rephrase this. Can any sort of avdance system be used in conjuction with a crank trigger ?? Being this is my pump gas streetable engine, I would assume that it would need to work to put a curve in the timing so that it would be friendly with pump gas. (Mechanical or Vacuum for that matter)
Travis,
Since the "triggering" is taking place from the fixed crank trigger pickup, the only advance system will be inside your ignition control box.
Any mechanical or vacuum advance in the distributor will only effect rotor phasing, having no impact on timing curve.
The programmable ignition systems let you tailor the curve to your specific needs.
Keith
Wheelie58
Wheelie58
Post  c.evans August 29th 2010, 10:50 am
Travis,
No,,,,,,the vacuum advance moves the breaker plate, thus it moves the magnetic pick-up attached to it. But since nothing is being triggered with the magnetic pick-up in the distributor, it would not change your timing.
Just use a rebuilt Ford Duraspark distributor ($50 + a core at O'Reilly's). Save or sell your crank trigger stuff. I really wonder how a MSD crank trigger would behave while driving your truck through a pouring rain, or snow, or tall weeds on the farm.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  richter69 August 29th 2010, 10:52 am
as stated using the crank as the trigger the timing will be fixed................no advance or retard. The dizzy must be modded as such the rotor is fixed to the shaft so it cant move.
Post  rmcomprandy August 29th 2010, 11:49 am
If you could find a way to move the pick-up while running then it could be done; vaccuum would be pretty easy but, RPM mechanically controlled advance would be a real invention.
TWO pick-ups with a switch are used in crank triggers all the time for starting the engine with the least advanced pickup.
Post  138 August 29th 2010, 3:43 pm
Travis do you have an extra complete trigger wheel set-up you wanna sell?
138
Post  maverick August 29th 2010, 3:57 pm
138 wrote:Travis do you have an extra complete trigger wheel set-up you wanna sell?
And one for me too? Very Happy
Post  badnotch August 29th 2010, 4:58 pm
i would sell mine but im sure i modified it to fit a jet fighter jet engine and it wouldnt work for you guys lol!
badnotch
badnotch
Post  richter69 August 29th 2010, 5:15 pm
badnotch wrote:i would sell mine but im sure i modified it to fit a jet fighter jet engine and it wouldnt work for you guys lol!
the modification would not be realized until the buyer took it out of the box...............
Post  badnotch August 29th 2010, 7:02 pm
thats why im keeping it Smile unlike most i dont need to sell it that bad i could put 100 pics up and wouldnt be enough cheers
badnotch
badnotch
Post  the Coug August 29th 2010, 7:48 pm
ok Les Cool it
Post  richter69 August 29th 2010, 8:37 pm
badnotch wrote:thats why im keeping it Smile unlike most i dont need to sell it that bad i could put 100 pics up and wouldnt be enough cheers
then why is it fore sale................ Question
Post  605FOX August 29th 2010, 8:43 pm
i hate to spoil this thread on the op ... but this guys needs to graciously leave this site ... he sent me a nice pm i would like to share :
JUST A THOUGHT
From badnotch To 605FOX, Fri 27 Aug - 19:57
YOU BETTER HOPE I NEVER RUN INTO YOU 0BECAUSE YOU WILL BE PICKING YOUR TEETH UP OFF THE GROUND
BEWARE OF MY FIST DOWN YOUR THROAT
605FOX
Post  TravisRice August 29th 2010, 8:43 pm
[quote="badnotch"]thats why im keeping it Smile unlike most i dont need to sell it that bad i could put it on for 100 bucs and then jack it up to $150 and it still wouldnt be good enough cheers [/quote]
My turn, I fixed it for you ..... Laughing
Post  TravisRice August 29th 2010, 9:00 pm
138 I will let you know if I decide to sell it. Maverick, you're second in line, I have 2 but will probably only get rid of the one.
Travis
Post  richter69 August 29th 2010, 9:01 pm
Sorry bout your thread Travis, but it had to be done.......... Laughing
Post  TravisRice August 29th 2010, 9:02 pm
[quote="605FOX"]i hate to spoil this thread on the op ... but this guys needs to graciously leave this site ... he sent me a nice pm i would like to share :
[color=red]
JUST A THOUGHT
BEWARE OF MY FIST DOWN YOUR THROAT[/color][/quote]
605, I guess that Gerry don't know you got false teeth. Smile
Post  TravisRice August 29th 2010, 9:03 pm
[quote="richter69"]Sorry bout your thread Travis, but it had to be done.......... Laughing [/quote]
NP HERO Laughing
