D0VE C Head question
56Tbird
posford
I'm looking at a pair of heads that are "supposed to be" D0VE C. The Casting numbers have been ground off for some unknown reason. Is there any other way to tell if they are, in fact, D0VE C ?
posford- Posts : 90
Re: D0VE C Head question
They have screw in studs and small combustion chambers. I'd be a little skeptical of them having DOVE-C ground off ? Could be D3VE's that someone put the studs in. The DOVE's use the large spark plug too, not sure about a D3 , I'll have to go look ?
56Tbird- BBF CONTRIBUTOR
Can you post some pic's of the combustion chambers/valves and do they have screwin studs for adj.rockers?
Dan,I think the D3's take the small 14mm plug.56Tbird wrote:They have screw in studs and small combustion chambers. I'd be a little skeptical of them having DOVE-C ground off ? Could be D3VE's that someone put the studs in. The DOVE's use the large spark plug too, not sure about a D3 , I'll have to go look ?
I haven't seen any d3ve heads with the big plugs in them not saying they where in made with big plugs just I haven't ever seen any.I have never seen a dove-c with small plugs in them except where someone had put the adapters in them.
I have both D3's and C8's ...D3=small hole C8=larger hole
138- Posts : 1593
Thanks guys, These have the 18mm plug hole, screw in studs.
posford- Posts : 90
Probably C8/C9/D0ve. Pretty much same head. But,don't know why someone would grind off the #'s
Thanks again. As far as grinding the numbers off, I guess it's one of life's little mysteries.
posford- Posts : 90
I have seen guys in mud racing and truck pulling classes grind off part or all of casting numbers to keep nosey people from knowing what they have.
lghting94- Posts : 762
bbf-falcon wrote:Probably C8/C9/D0ve. Pretty much same head. But,don't know why someone would grind off the #'s
Getting the weight down.
342g- BBF CONTRIBUTOR
SCJ heads have the 14mm plugs
» D0ve cylinder head question?
» EFI vs D0VE head questions
» D0VE head and compression q's
» D0VE head work
» D0VE head c/w gaskets
» D0VE head work
