Ford diesels
+18
prosandguy
Diggindeeper
hayhauler
LivermoreDave
bb429power
557 mazda
KY JELLY
56Tbird
OldRedFord
22 posters
Ford diesels Empty Ford diesels
Post  OldRedFord September 11th 2010, 11:54 pm
So my truck search has turned to just used trucks. As far as looking online I have looked at Ford power Strokes and Dodge Cummins. The Cummins used are pretty slim pickings around here.
Should I avoid the 6.0 all together? I know they had issues but with head studs and the bracket that holds the goofy valve thing in the HPOP and not beat the hell out of it I should be ok right?
As far as the 7.3s when your looking at one with 200,000 miles on the motor is it approaching the end of its life?
OldRedFord
OldRedFord
Ford diesels Empty Re: Ford diesels
Post  res0rli9 September 12th 2010, 12:14 am
ask Bruno if you should get a 6.0 Rolling Eyes
Post  richter69 September 12th 2010, 12:17 am
6.0 will leave you broke and pissed off.........its too bad because the rest of the truck
is awesome.
Post  cool40 September 12th 2010, 12:47 am
diesels suck! Laughing Ford diesels Race_c10
Post  56Tbird September 12th 2010, 8:32 am
My 7.3 just turned 210,000 and still doesn't use any oil ,even when towing. I hope it'll run another 200,000 .I really like it ,but wuth fuel prices ,I'm not sure I wouldn't replace it with a gas burner.Everytime there is a repair on a diesel ,you can expect a $1000 repair bill at least.Good luck!!
56Tbird
56Tbird
Post  bbf-falcon September 12th 2010, 8:54 am
I know of 3 different 7.3's w/over 300k and don't show any sign's of slowing down. Harold ,I want your truck Very Happy
Post  dfree383 September 12th 2010, 9:28 am
How much towing do you intend to do??? How heavy?
As far a life of the engine, it has alot more to due with type of use and maintenance , rather than just milage.
Post  69F100 September 12th 2010, 9:46 am
Don't know about the 6.0 but we have 2 7.3s one a 2000 with 276,000 on it and a 2002 with 236,000 on it and they still run great and don't use any oil.We have a 2008 with the 6.4 but it has not been that good been to the shop many times and it only has 58,000 on it. these miles are road miles pulling Pace Trailer on them.
Post  KY JELLY September 12th 2010, 9:50 am
I have been told $12,000 would buy this truck 2002 f-250. Its local to me so I can go look it over for you if you are intersted.
Date Posted: August 17 Date Modified: August 29
Expiration: September 16 Category: Autos/Trucks
Phone: (270)851-7884 Email Replies: 0
Hits: 455 hits Account Type: Classic
THIS IS A ONE OWNER, SUPER SHARP TRUCK,PEWTER IN COLOR.IT ALSO HAS A EXTRA SET OF TIRES. EVERYTHING WORKS ON THE TRUCK. 160,000 MILES 14500.00 DO NOT SEND EMAIL. THIS IS A FRIENDS TRUCK ,ONE OWNER.CALL THIS NUMBER ONLY 994-7134- BRAD THIS TRUCK GETS ON AVERAGE 20 MPG
KY JELLY
KY JELLY
Ford diesels Empty diesal truck
Post  557 mazda September 12th 2010, 10:02 am
My 1996 ford f-250 4x4 has 334000 miles and still runs like a new one... I wonder how many more thousand it will run....
557 mazda
557 mazda
Post  jbozzelle September 12th 2010, 10:11 am
That truck KY posted sounds like a good deal. I have 329,000 on my 2001 7.3 and it runs fine. My dad has 340,000 on his 2000 7.3 and it runs fine too. I bought mine with 228,000 on it and have had a few small problems but it's stuff I fixed myself, except for changing 2 injectors. I let the shop do that simply because I didn't have the time. My trans lasted until 298,000. But it snapped the input shaft. We upgraded it a little while we were in there.
The 6.0s to me are a crap shoot! I know guys with some and they have had ZERO problems with them. And then I know guys like Bruno that have nothing but problems. My 2008 6.4 ain't much better either. It's hade constant problems with the DPF since 49,000 miles. It now has 94,000 on it. I don't like the engine or the problems, but the truck itself is nice. It's quiet, smooth and clean. It's everything my old 7.3 isn't, minus the engine...
Go for a 7.3, you'll be happy you did.
Post  bb429power September 12th 2010, 10:32 am
Keep in mind the diesels have like twice the life span of a gas engine, so 200,000 isn't close to the end. I have seen gas engines go 470,000 miles without any repairs but valve seals and run like new and start right up. The new 6.7 powerstroke is sweet! Cool
bb429power
bb429power
Post  richter69 September 12th 2010, 10:58 am
know of at least 3 7.3's with over 800k..........trucks are a pile of crap though.
have seen a couple 6.0's over 300k..........not original motors.
one 6.4 with nearly 200k with the original powerplant...........it should be put in a museum.............
for all the 6.0's that have never had a problem..............they all have the same issues and will break sooner or later.it cant be helped.......would rather all the breakdowns occur under warranty like Nick's..he only has like 7 failures left........ Laughing
Post  LivermoreDave September 12th 2010, 11:31 am
I looked high and low for a F250 w/Powerstroke, and preferred the 2001 model. I asked a lot of people I knew about the engines other than the 7.3. The preference was the 7.3 model, but the year model may only offer a "run down" truck! I lucked out, found a very nice truck w/80k miles , one owner and like new! The 2001 7.3 model of the Powerstroke continues to amaze me of it's towing ability, as well the trucks ability to safely tow a 28' enclosed trailer loaded with my cargo!
I have a '82 F150 w/460 power. It pulls nicely although at the half-ton rating it's not up to the challenge of "safe towing", especially a 28' enclosed trailer. I think a nice 3/4 ton or 1 ton rated platform w/460 power could do a very nice job of all but extreme towing. Another item to add to your package (IMO), 4 wheel disc brakes, those are a must!
I like the 3/4 ton chassis, the 1 ton chassis is nice too if you don't mind a "big truck"!
Dave.
LivermoreDave
Post  Lem Evans September 12th 2010, 11:44 am
Dave, have you ever driven a 'big' truck?
Post  hayhauler September 12th 2010, 11:48 am
i have 230,000 on my 99 f250 and it still runs like new but it does have a slow power steering leak that is hard for me to find.
hayhauler
Post  richter69 September 12th 2010, 11:54 am
the title should be "Ford trucks with Navistar diesel", unless its a 2011.............. Wink
Post  Nevs September 12th 2010, 12:03 pm
Lem Evans wrote:Dave, have you ever driven a 'big' truck?
I do every day, Lem! Laughing Wink
Post  Lem Evans September 12th 2010, 12:32 pm
So does Dave Smile
Post  OldRedFord September 12th 2010, 1:31 pm
dfree383 wrote:How much towing do you intend to do??? How heavy?
Five days a week Im pulling 3000 lbs. I know thats nothing but its a lot for my little Ranger. There are scrap metal jobs I take on that I would like to be able to haul a bit more. Also want to be able to pull a tractor or a backhoe around.
OldRedFord
OldRedFord
Post  Diggindeeper September 12th 2010, 9:33 pm
7.3 IDI turbo FTW.
i had 400k on mine, pulled better than a non chipped 7.3PSD. only thing replaced was the injector hats and lines.
Diggindeeper
Diggindeeper
Post  prosandguy September 12th 2010, 9:49 pm
I can only post about what I personally have, but my daily driver (personal) is a '97 CC PSD F250, currently have 144K on it and best truck I have ever owned. I just pulled my 44ft Pace gooseneck to MO and back, 10.6mpg there and back with 2 BAD in the rear, I was very pleased with how it went. The only things I have replaced so far are the batteries, a vacuum pump, cam position sensor and the belt tensioner pulley, and I have put just about 65K on it since I bought it.
My other daily driver is a '95 Ford school bus with PSD, 187K on the clock there. Still goes down the road great and gets driven 110 miles a day, more with field trips and such. I figure if a power stroke can make it in a bus, it will survive my driving for quite a while.
prosandguy
prosandguy
Post  bb429power September 12th 2010, 10:48 pm
My uncle drives a school bus for my area, its the short bus. But he's driven the big ones and told me about making turns in them, I want a 4x4 school bus!
bb429power
bb429power
Post  John I. September 13th 2010, 12:36 am
I bought my 2006 SD used over 2 years ago, and have done nothing to it, but that is about to end. It's missing when it's cold and down on power warm so I expect the ficm or a couple of injectors are at fault. It's starting to lose coolant, so I expect the egr cooler is giving up. I absolutely love that truck, and that's why I'm going to tear into it this fall and spend a week and several thousand dollars doing head studs, oil and egr coolers, stc fitting, turbo cleanout, coolant filter, guages, and anything else it needs or is going to need. It's a shame us Ford guys have to do this stuff just to make the engine comparable to a duramax or cummins, but the truck it's sitting in is why I'll do it. Hell, just not having to pull that abortionate shift lever into gear on the Chev makes it worth while. Very Happy
John I.
Post  LivermoreDave September 13th 2010, 8:09 am
A big truck ? No!
Ford diesels Bigtruck
Dave.
LivermoreDave
