C6 ?'s stall and trans brake
Bought a trans from a forum memebr. It has a TCI 441300 converter and TCI VB with brake. My father owns a trans shop with great rep and has been building for over 30 years. Back in the day he ran some pretty healthy mud toys. He is sticking to his guns that any kind of high stall converter is a bad idea and will kill my trans is short order. My take is and from what I see running (including my past toys) that if temps are in check you should be good to go. This truck is a 2002 reg cab short box Superduty, 545 c6 205 on 1 ton axles 4.88. Looking to run 40-46" rubber. Dont know the weight yet. We are pulling the trans down to look it over and see how healthy it is.
My questions are: would you run that converter and does it seem to be in the ballpark for stall?
Are all TCI brake VB in need of the check ball slot mod or has TCI fixed their patterns to take care of the issue and if so can you check a build number to see what run you have?
paperman- Posts : 88
Re: C6 ?'s stall and trans brake
Temp is the main deal here.............. I have ran big converers on the street and have never had an issue. But I also always ran a big cooler too.
I know heat kills but in an off-road truck air flow can be a challenge. On the street you can get a good flow of air after you work the converter on a launch. Off-road like in sand or mud you work it hard then roll slow.
True.......... And on the street around town a converter never realy locks up just slipping all the time.
» Trans brake
» C6 with Merkley brake,5500 stall
» C4 TRANS BRAKE
» How can I trans brake my c6 without.......?
» C6 Trans brake
» C4 TRANS BRAKE
» C6 Trans brake
