Aluminum head info needed
Does anyone know of a manufacturer of aluminum heads that DO NOT have a raised exhaust port? I need a set for a 460 conversion into a 64 Ford Fairlane. The aftermarket headers (Crites) will not clear if you use raised port heads. Thanks
olddude- Posts : 1
Re: Aluminum head info needed
Edelbrock RPM, Ford A429, Blue Thunder w/Ford exhaust port.
heads
Some Blue Thunders with Ford exhaust have the raised port, mine are that way. I would guess you can probably order them either way.
blown473- Posts : 376
» camshaft tech info needed
» C-heads info needed
» TFS A460 info needed
» Head Gaskets Needed
» Turning down the crank and other info needed please
