SFI cert question
SFI cert question
I was wondering if anyone knows where to find the definition to the SFI specs, I'm looking for 6.1 (bellhousings) and 1.1? (clutches). We had a truck lose a clutch the last two weekends luckily no one was hurt but this last weekend a piece of clutch cut the fuel line and the truck burnt. Both cases had Lakewood bellhousings and was just wondering what exactly they were supposed to hold up to?
curiousgeorge- Posts : 191
Re: SFI cert question
curiousgeorge wrote:I was wondering if anyone knows where to find the definition to the SFI specs, I'm looking for 6.1 (bellhousings) and 1.1? (clutches). We had a truck lose a clutch the last two weekends luckily no one was hurt but this last weekend a piece of clutch cut the fuel line and the truck burnt. Both cases had Lakewood bellhousings and was just wondering what exactly they were supposed to hold up to?
Have you tried the SFI website? If nothing else you could email them the question.
Nevs- BBF CONTRIBUTOR
I tried the website and all I could find was what was covered not the explanation of to what extent. I was told once that a steel lakewood was supposed to absorb a flywheel at 8000rpms but that is all I've ever heard. IMO if they can take a flywheel a clutch and pressure plate should be no prob for them. Haven't talked to the guy yet and don't know how long it has been since the pressure plate or bellhousing have been cert.
curiousgeorge wrote:I tried the website and all I could find was what was covered not the explanation of to what extent. I was told once that a steel lakewood was supposed to absorb a flywheel at 8000rpms but that is all I've ever heard. IMO if they can take a flywheel a clutch and pressure plate should be no prob for them. Haven't talked to the guy yet and don't know how long it has been since the pressure plate or bellhousing have been cert.
Gotcha. What about calling Lakewood? I would think they should have the answer as well.
curiousgeorge wrote: We had a truck lose a clutch the last two weekends
When did the clutch exit the bell? The first time or the second?
jbozzelle- Posts : 3705
jbozzelle wrote:curiousgeorge wrote: We had a truck lose a clutch the last two weekends
I should have said trucks. It was 2 different trucks, the first one the bell seperated from the block and both disks were laying on the ground complete.(I've heard rumor that he did not have all the bellhousing bolts in but that's just hearsay) The second one I've been told was the pressure plate that exploded and pieces came through the bell. I don't know if they had been cert. in the last 5 yrs or not but it's making me think real hard about everyones saftey at the pulls. I'm begining to think we need to step up to the 6.3 housings with liners. 6.1 is supposed to cover everything up to a dual disk and a triple up to 8 inches.
Gotcha. Maybe the heat would affect them after so many years. The only thing you can do to test them is non-destructive testing like magnaflux or x-ray. But that will not tell you if the metal is fatigued to the point of being weak enough to seperate.
I'd call Lakewood and get their take on it.
What are you running? A puller? I know that IHRA/NHRA do not allow fuel line to be routed inside the frame rails unless housed in steel tubing of .083" wall thickness and minimum of 18 inches in length.
» New SFI cert is out 25.3
» 7.50 CERT UPGRADE ?
» CHASSIS CERT QUESTIONS
» Chasis Cert
» IHRA chassis certs at the Ford race. Anybody interested. Please respond.
» Chasis Cert
