High compression topic, dish vs flat top vs dome.
+10
KY JELLY
DanH
14 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: High compression topic, dish vs flat top vs dome.
Jon , i covered that in my first post in this thread . there is no one rule for pistons that fits all engines . who's going to run a dome piston iin a 34cc Yates head 408 inch sbf.
DanH- Posts : 1081
I did not say anywhere you should run 17:1 . I said 17:1 would work fine with alcohol
I do know for fact that knocking on 16:1 WITH A P-51 is not detrimental don't I
KY JELLY- Posts : 1530
I agree, cutting the heads a bunch to get there is not a good idea.
I guess you will find out when you get the timing set , I would suppose lower than mine by what you have been telling me about flame propagation etc
Unless ole KY is right about dome area helping to vaporize alcohol better and you have to run a little more timing like Charlie's 533 had to with Flat tops and scj's
KY JELLY wrote: I guess you will find out when you get the timing set , I would suppose lower than mine by what you have been telling me about flame propagation etc
28.5 degrees of timing with a dome to get max hp (er best performance).................... something is working right.
"something is working right"
Yes sir and it's called the P51/SCJ combustion chamber and spark plug location.
Not familiar with the roundy round stuff at all. But someone please expound on why they like the cut the heads a bunch to get high compression with flat top pistons (very lightweight) so they can spin the crap out of it. If that method is better for high RPM's and on and off the gas situations as well as the shops claiming that it helps head flow......why would we not do the same......what is better......why??
away- Posts : 266
Chevy guys wish they was us...................
away wrote:Not familiar with the roundy round stuff at all. But someone please expound on why they like the cut the heads a bunch to get high compression with flat top pistons (very lightweight) so they can spin the crap out of it. If that method is better for high RPM's and on and off the gas situations as well as the shops claiming that it helps head flow......why would we not do the same......what is better......why??
My first guess is that it's becaue they are only allowed to run a certain part number "claimer" piston.
jbozzelle- Posts : 3705
jbozzelle wrote:away wrote:Not familiar with the roundy round stuff at all. But someone please expound on why they like the cut the heads a bunch to get high compression with flat top pistons (very lightweight) so they can spin the crap out of it. If that method is better for high RPM's and on and off the gas situations as well as the shops claiming that it helps head flow......why would we not do the same......what is better......why??
Or a flat top piston rule, we have that here. stock stroke, stock rod length, flat top piston, and steel heads.
richter69 wrote:how big is a "nano" dome? .050? its not like they are Pike's Peak or anything lol.
The whole "skeeter" comment is what started this, truth is his "domes" are not that much of a dome............prolly why it works so well.
Add up the surface area of the dome you have vs a flat top...I'm sure the difference is marginal at best. If vaporazation is what your concerned with thats where M3 and M5 come into play.
If I had about .012-.015 more height on the dome I would be right at 17:1. You need to decide if your "theory" depends on compression ratio or dome height this ain't no bbc I got , it don't take a 1/2" dome to get there
I have compared the flat top v/s the dome with Charlie's 533 and this 562 with (same or very very similar combustion chambers) I know what runs the best with less timing. And it ain't the flat tops
richter69 wrote: But the two engines had different heads, cams, etc..................so the test results are inconclusive.
You'll need to stick that 562 on a dyno and change pistons to test your dome theory.
I'll venture a guess my flat top motor will make as much if not more than you dome motor..................I took the money I saved on rebalanceing it and spent it in other places that will be more beneficial...........
Let me know how much that smog pump that will barely pull 4" on a non running engine helps...........
wanna put 5 grand on it same dyno ?
[quote="richter69"]
Let me know how much that smog pump that will barely pull 4" on a non running engine helps........... [/quote]
TravisRice- BBF CONTRIBUTOR
I got a drysump pump and pan setting in the closet I can have on this thing in just a jiffy , I don't see me using a s-10 vac pump like you are getting "mad' and suggesting.
I don't guess you were paying attention when I told you Travis is sending me his belt driven vac pump to try out ?
YOU NEED TO LEARN TO CONTROL YOUR HeRO "emotions"
You know the problem with the internet is you don't know how to take someone. I'm not gettin into a pissin' contest over some idea's that neither one of us could prove anyway on a dyno or a racetrack.
I consider you a friend Randy, I'm not going down the same path I did with Dan, we ended up fixing it but I'm not gonna go through it again.
I'll delete all my negative posts, and start by saying I'm sorry. Its not that I think I'm wrong or your wrong, just not gonna get into this situation.
Now any of you other motherf-ers wanna have a go lets get it on..........
[quote="richter69"]
Now any of you other motherf-ers wanna have a go lets get it on.......... [/quote]
Aint you got a storm to chase somewhere ?? Wait, I guess that makes me a smog pump wear'n no runnin mfer ?? Damn I feel important now.
You're a pussy! (without shaft rockers)
Curt- Posts : 2791
no storms......but the Discovery show comes on in like 3 weeks lol.
and Curt, I challenge you to a pushrod duel...........
Challenge accepted!
Curt- Posts : 2791
I am not mad , and you don't owe me an apology. I told you what I think and I firmly believe what I said .
Like I said before I understand why you are using what you are and that's fine , but I was stating my opinion to what you posted and you kept posting so YOU KNOW THE REST OF THE STORY
No hard Feelings Mr FABIO
I still have your pic in my album too
I don't care who you are,,,,,,,dat right there is funny
Mr. Fabio Fashion,
There is two different prices on your P(DD)51 cylinder heads. One price if you come to the next Bash,,,,and a much higher price if you don't come to the next Bash Plus, you'll get to meet DD Tonya if you do come.
Uncle Charlie
Mr. Fabio Fashion,
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
KY JELLY wrote:I am not mad , and you don't owe me an apology. I told you what I think and I firmly believe what I said .
Well I still firmly believe in what all I said as well, I'll leave it at that lol.
Man it was hot that year at the bash, and not just because I was there.............
I'll start saving some money for the fuel bill to come see those DD's in person, best to leave the wife at home..but i doubt that will happen...........
Bout time to get a smack talk thread underway for next year.................
» KB Pistons. Can I mill a dish in the flat tops?
» Looking for 4.440 1.250ch A460 pistons flat top or dish
» High compression and turbo ?'s
» High compression and dual batteries
» Looking for ideas on how to build a high compression 429
Page 2 of 3
