Bruno, thanks for induction solutions, check this out!
jones
blown473
Bruno, thanks for induction solutions, check this out! Empty Bruno, thanks for induction solutions, check this out!
Post  blown473 September 25th 2010, 11:07 am
Some testing video, we could not add the nitrous and extra fuel or it flips the test stand over. As it is its anchored to the ground and it almost gets away. The final engine will be polished stainless. The guys at Induction solutions have a new market for their stuff now, pulse jet enhancement !!!
https://www.youtube.com/watch?v=IFj9dGZF_zc Very Happy
blown473
blown473
Bruno, thanks for induction solutions, check this out! Empty Re: Bruno, thanks for induction solutions, check this out!
Post  Curt September 25th 2010, 11:16 am
cool Cool
Post  jones September 25th 2010, 11:06 pm
Never heard of a Pulse Jet Engine, what can you use them for?
jones
Post  res0rli9 September 25th 2010, 11:20 pm
jones wrote:Never heard of a Pulse Jet Engine, what can you use them for?
going to tha moon if ya not careful
Bruno, thanks for induction solutions, check this out! Empty whats a pulse jet
Post  blown473 September 26th 2010, 1:42 am
Pulse jets have been around for a long time. They are most well know as the "Buzz Bomb" that Germany launched against England and Belgium durning World War 2. They were the engine of the worlds first cruise missile. They propelled a 3000 + lb missile 400+ mph. After the war, Ford Motor Co. produced them for the US military, taking the German design and improving on it. Ford's version was called the "Loon" cruise missile. Pulse jets are very simple in design, and can be built with or with out valves, the easiest of all jet engines to produce. The valved design makes the most power. Mine is a full scale copy , but with enhancements, full stainless steel construction, nitrous injection for higher power, and an improved tail cone . Pulse jets work off reversion, air is drawn in, fuel is injected to it, it passes through compression plates into the combustion chamber where its ignited, as the combustion expands it closes the intake valves and the exhaust rockets out the tail pipe. As the exhaust pressure falls a low pressure area is created behind the intake valves opening them to start the process all over again. A small amount of air is also drawn in from the tail pipe. This cycle happens hundreds of times per second, the engine actually looks like its constant running, but in fact it cycles on and off to fast to see. Its a very effective motor. Its only short coming is high fuel consumption. It burns 6 gallons a minute or more at full throttle. Thats why modern cruise missiles use turbo jets to have much longer range. Noise is also high at 140 db. , so its not stealthy. Pulse jets are becoming very common around the world today, you see them in everything from hobby size radio controled airplanes to go karts, bigger units in dragsters, even kits on regular peddle bicycles. Bob Maddox of Medford ,Oregon built mine, he's probably the most knowledgeable pulse jet man on the planet. If you google or you-tube his name you can see my engine, and tons of other sizes and applications he has built. Mine was built to take on Bonneville, so max thrust performance was the goal, thats why we went full scale on this motor, and made the mild steel proto type test engine shown in the video. The finished product is all stainless, show polished, with the improved tail cone. Much stronger, more heat resistant, and has adaptability to further enhancements we are working on. I really wanted to do something very different, but wanted the truck to stay all Ford. So the blown new 514 goes up front, and our copy of the Ford Loon motor goes out back. We call it double blue oval power! Let the fun begin!! Greg Very Happy
blown473
blown473
Post  hillbillyerv September 26th 2010, 2:33 pm
that`s frikin cool:) good luck on the flats Cool
hillbillyerv
hillbillyerv
Post  bruno September 27th 2010, 9:13 pm
cant wait to see the results greg !!! Twisted Evil
http://WWW.CKRME.COM
Post  D's557BBF September 28th 2010, 6:53 am
You can read post on here until you are blue in the face and not read anything funny. Then one day you read one and it catches you just right and you laugh your ass off for days!!! The above remark caught me just right!!!!
D's557BBF
D's557BBF
