Class C RV rear frame reinforcement
+9
KY JELLY
D's557BBF
56Tbird
D. Sea
13 posters
Hey guys,
I just got my RV back from Bill Mitchell.
The previous owner had put some metal in the rear frame to stiffen it up but I felt it was inadequate for my application so I got Bill to work his magic and reinforce it the correct way. When I get a chance, I'll get some pictures but it's NICE!!! It's all boxed, triangulated and cross braced. I think I could pull a TANK with this RV now
Thanks Bill......... Like I told you a few weeks ago, I wanted you to do the job because I knew it would be done correctly.
D. Sea- Posts : 2768
Re: Class C RV rear frame reinforcement
I've gotta get w/Bill to see if he can redo the Alum. in my Falcon after Christmas. Hope he can work me in.Post some Pic's of the RV Damon
Will do Rick. I have to get some more pictures, this is all I have for now.
What's the tongue weight on the trailer? A friend of mine thought about reinforcing the frame on his Class C but decided against it and bought a trailer toad instead.
He said the frame can't take the tongue weight but could pull it no problem.
jbozzelle- Posts : 3705
I'll never attempt to pull with a class C again without a trailer toad. It ain't the frame you've got to worry so much about, as it is the tongue weight. You better just get used to driving with both hands clinched to the sterring wheel and your butt stuck to the seat. Your in for a big learning experience my friend. If it rains ...park it!! Good luck Damon and be very careful. I did it for years, it can be done, but it's NOT safe!! The right dip in the road and it'll get buck jumping until the front wheels will about come off the ground.Happy RVing buddy
56Tbird- BBF CONTRIBUTOR
56Tbird wrote:I'll never attempt to pull with a class C again without a trailer toad. It ain't the frame you've got to worry so much about, as it is the tongue weight. You better just get used to driving with both hands clinched to the sterring wheel and your butt stuck to the seat. Your in for a big learning experience my friend. If it rains ...park it!! Good luck Damon and be very careful. I did it for years, it can be done, but it's NOT safe!! The right dip in the road and it'll get buck jumping until the front wheels will about come off the ground.Happy RVing buddy
Damon, The one thing I have learned since joining this website is " When Dan Hobbs say's something it's as good as GOLD!! He may have a mullet but he has been there and done that...
Now get them pics up man!!
D's557BBF- Posts : 1186
I'll be getting a trailer toad but don't have one at the momment. I'll drive slow this weekend
I bet alot of it has to do with how much tongue weight you have as well as how long of an overhang you have past the rear wheels. The longer the overhang the more leverage the trailer has to pull wheelies like Dan is talking about.
Are you taking the motorhome and truck/trailer to BG Damon?
jasonf- BBF CONTRIBUTOR
jasonf wrote:I bet alot of it has to do with how much tongue weight you have as well as how long of an overhang you have past the rear wheels. The longer the overhang the more leverage the trailer has to pull wheelies like Dan is talking about.
That's the plan. Fortunately a good friend loaned me his trailer
I don't think the RV can tow my trailer
I am gonna have to get to work on them things This tough tow deal looks pretty good to wonder how they work ?
https://www.shogunindustries.com/cgi-bin/ws400CS.cgi?cart_id=1100927040412222&page=tufftowintro.htm
KY JELLY- Posts : 1530
tough tow works great from what I have heard from costomers at work.You have to weld some extra bracing in for it.We offer a tough tow package with all the braces welded in for it.
Jim
Jim
It just looks like it would be more stable to me ? I don't like the idea of having a link between the trailer and the tow vehicle , but the toads seem to work good talking to the people that use them.
Are you bumper pull guys using a weight distributing hitch of some sort? you should with these big heavy trailers.
I pull a 34' enclosed w/bumper pull. Its heavy as hell but I have weight dist. bars on it and my single wheeled 97 Ford ps diesel don't weeve at all. But,if I did'nt have them it would be scarry to drive.
richter69 wrote:Are you bumper pull guys using a weight distributing hitch of some sort? you should with these big heavy trailers.
My 24 ft pulls good behind my 93 dually, but I wouldn't attempt it with a single wheel truck with out the WDH bars on it.
I don't use anything on my 2000 , got air bags on my 2001 , both pull fine , but the air bags are definitely better, they take the bounce out. My opinion I think they are better than the bars because you can adjust to the trailer you are towing with a little air pressure .
Wieght in a trailer needs to be 60/40 that is from the center line of the axles with 60% of the load to the front and 40%to the rear.You can also use this on building your on trailer the 60/40 factor the 60/40 is frame only not counting the tung.
Trailer Toad
It works great for me. 32' MH and 34' trailer
Dagwood- Posts : 33
KY JELLY wrote:I don't use anything on my 2000 , got air bags on my 2001 , both pull fine , but the air bags are definitely better, they take the bounce out. My opinion I think they are better than the bars because you can adjust to the trailer you are towing with a little air pressure .
You can achieve the same by dropping or raising a link ot two on the chains on the bars.
D. Sea wrote:Will do Rick. I have to get some more pictures, this is all I have for now.
With a picture like that (top), why would you want to post another? Surely none better! I believe that girl has found the "Fountain of Youth"!
Dave.
LivermoreDave- Posts : 972
https://www.shogunindustries.com/cgi-bin/ws400CS.cgi?cart_id=1100928100205407&page=products.htm&view_item=TT90196
Link didn't work for me Randy so I made another.
Dave, I'll let Tracy know that you said that
I loaded the car last night in Blakes 24' trailer. Alan was over picking up an intake manifold and a crank. He suggested maybe I could load the car backwards in order to take some weight off the tounge. With the wheelie bars on the car, I'm a few feet from the rear...
I use Air Lift bags on all of my trucks. Very pleased with their products.
The kits run for about $ 180.00 and is worth every penny !
83-88T-Bird Guy- Posts : 1003
» HOW ABOUT A 1/8 MILE CLASS NEXT YEAR???? H.D.R.A. new class?
» need some more parts !
» 55 staight axle swap 02 ranger ifs donor truck
» New 57 Ford Project Should we go big block or small block? Pics added
» sub frame connectors
