New best 60ft. 1.3020
Ed501
New best 60ft. 1.3020 Empty New best 60ft. 1.3020
Post  Ed501 September 27th 2010, 11:06 pm
managed a 6.18 with a 1.39 60ft. in the heat of day before the air got good, 1600ft 66 humidity and 79 degrees. Tryed it tied down and spun through most of 60ft with a 1.55 60 ft. I wish a really good track was closer.Car hooked once but went toward the center line packing the fronts ,had to lift on the 1.30 60ft. Allwell someday i will get it lined out i hope. Shocked
Ed501
New best 60ft. 1.3020 Empty Re: New best 60ft. 1.3020
Post  DILLIGASDAVE September 28th 2010, 12:42 am
What kind of track prep (if any) are they doing?........
Are they spraying the track with any traction compound (and if so, which brand)?
Are they scraping the starting line often enough to keep the excess rubber build up/ripples/ocean-waves in check?
Are they scraping the starting line too often, never allowing enough rubber to build up?
If there is an oil-down, how do they clean it up?
Do they just mop the spill?
Do they broom in an absorbent?
Do they burn-off the spill?
Or any combo of the above?
It can be amazing how bad the track prep can be at some tracks, & how expertly done the prep can be at others.
New best 60ft. 1.3020 Empty the good ole white mop on starting line.
Post  Ed501 September 28th 2010, 2:57 am
It seems tub cars work good and thats what they care about. Track always hooks alot better at night. Been rumored around that they use cold weather traction compound and it doesnt work good when track surface is hotter. Might just be a rumor though. All my friends running small tires were having alot of inconcitences with there 60ft. They dont do much if any prep during test and tune i hear.They did have some oil downs during the night witch had to factor in.
Ed501
Post  whatbumper September 28th 2010, 8:38 am
I would bet money they scrape too much.
Post  bruno September 28th 2010, 8:46 am
also if it is a test and tune night ...most track facilities arent going to invest much time and money in track prep. usually my best 60',et,mph are at events
http://WWW.CKRME.COM
Post  bbf-falcon September 28th 2010, 10:25 am
bruno wrote:also if it is a test and tune night ...most track facilities arent going to invest much time and money in track prep. usually my best 60',et,mph are at events
Thats pretty much true at all tracks
Post  Curt September 28th 2010, 10:42 am
Ed501 wrote:Track always hooks alot better at night.
Until it gets really cold, it will always hook better at night.
