Tieing down a fox body
I am trying to get ready for BG and am wondering the best way tie down the front of a fox body Mustang? It is a 93 lx convertible if it matters.
jasonf- BBF CONTRIBUTOR
Re: Tieing down a fox body
when you say tie it down ...what do you mean ...from doing wheelies ???
bruno wrote:when you say tie it down ...what do you mean ...from doing wheelies ???
Hahahahah good one Bruno. I mean tie it down in my trailer. I initially thought I would just go between the pan and the xmember but there is not enough room to fit my tie down straps through. Maybe I will need to use a chain in the front instead or some other method. All my other cars have lots of room so I have never ran into this problem before.
I used to use ratchet straps with hooks and tie to the factory assembly points on the front frame rails. (the oval holes). Now with a tubular crossmember we tie to the crossmember where it turns up from the oil pan area. I have the little pieces with hooks on each end to tie my ratchets to.
whatbumper- Posts : 3024
X2....The holes in front of the struts and then, criss-cross the straps.whatbumper wrote:I used to use ratchet straps with hooks and tie to the factory assembly points on the front frame rails. (the oval holes).
Treeyasoon- Posts : 759
X2Treeyasoon wrote:X2....The holes in front of the struts and then, criss-cross the straps.whatbumper wrote:I used to use ratchet straps with hooks and tie to the factory assembly points on the front frame rails. (the oval holes).
bb429power- Posts : 3129
» Somebody getting a new Project/Toy
» any body seen this???
» any body else
» WTB - Fox body BBF oil pan
» Went to Indy this week
» any body else
