99 f250 door opening problem
99 f250 door opening problem Empty 99 f250 door opening problem
Post  Larry T October 10th 2010, 1:27 pm
i have a 99 f250 extended cab with the small rear doors i cant get them open.i can lock the doors from the inside manually and lock out side with a key.when i try to use the auto lock on the door it dosent work.is the problem with the auto door lock the reason i cant get the rear doors to open?
Larry T
Larry T
99 f250 door opening problem Empty Re: 99 f250 door opening problem
Post  69F100 October 10th 2010, 2:10 pm
Larry don't know if your rear doors are set up like my 2000 ranger was it had the power locks but the rear doors did not have any kind of lock in them when i stripped them down.
Post  Larry T October 10th 2010, 3:20 pm
hummmmm if that is the case i cant get to the latch in side with out opening the door to get the panel off first.i dont know what to do next?you guys got any ideas?
Larry T
Larry T
Post  69F100 October 10th 2010, 6:34 pm
Larry mine has a 2 cables that runs from the door handle to both the latches one to the top and one to the bottom. It will be a pain to work on for sure without opening the door to get the panel off.
Post  DFI429 October 10th 2010, 7:41 pm
Larry, I have a 2002 F-350 extended cab short box, and tried the back doors after pushing the lock & un-lock button, and it made no difference. It appears the locks only affect the front doors. Maybe your rear door linkage gave up somehow.. scratch
Hope this helps
DFI429
DFI429
Post  Larry T October 10th 2010, 10:24 pm
well i dont want to go to the dealer if i can help it.i know some guys that do body work maybe they have seen this before?
thank you guy's for your help.
Larry T
Larry T
Post  cool40 October 10th 2010, 11:49 pm
the front doors have nothing to do with the rear,as far as locking or latching the rear doors. you may have a broken handle or the rods/cables may be loose.it's been a while but i think those doors have rods to the upper and lower latch.when you pull the handle,shake the door hard and it may open,i'v done it before.good luck Smile
