Do a460 headers fit p51s?
bcr466
Bernie
Do a460 headers fit p51s? Empty Do a460 headers fit p51s?
Post  Bernie October 14th 2010, 8:33 am
As the title says. I'm pretty sure they don't...
Bernie
Do a460 headers fit p51s? Empty Re: Do a460 headers fit p51s?
Post  dfree383 October 14th 2010, 9:18 am
No they don't fit, but if you have a dragster or chassis car you may get them to work using a set of Charlie Evans adaptors to bolt BBC headers to the regular ford ports. I wouldn't think it would work with somehting like a fox body though.
Post  bcr466 October 14th 2010, 1:16 pm
dfree have you got a pic of these adapters, or anyone else? i did a search and cant find anything. I have some headers that came with the Tbird with bbc pattern flange. I didnt want to hack up two sets of headers and the adapter may be just what I need.
bcr466
bcr466
http://cracing@frontiernet.net
Post  dfree383 October 14th 2010, 1:25 pm
I don't have any Pics. Give Charlie Evans a call or maybe check-out his website.
http://www.evansracingengines.com/contact.html
Post  richter69 October 14th 2010, 1:29 pm
I have a set here I borrowed for the dyno session, I'll try and get some pics tonight.
EDIT; there are pics on the link above.
Post  bcr466 October 14th 2010, 2:55 pm
They look like they might do what I need. Now if I dont have to takeout a loan to buy them.
Thanks for info and pics.
bcr466
bcr466
Post  c.evans October 14th 2010, 7:12 pm
The header adapters are $240 + shipping.
Thanks,
Charlie Evans
(270)685-4654
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  schmitty October 14th 2010, 10:39 pm
Once you use Uncle Charlie's adapters you will wonder why you ever tried to mount up headers any other way. I have a pair and they make header mounting a pleasure. Be aware that they are made to fit the floor contour of the TFS Streets and the floor of the adapter ports will be above the floor of standard ports. I have seen no problems associated with this mismatch on my DOVE heads though. Cool
Post  c.evans October 14th 2010, 11:12 pm
You can port match them if you want. It is easier to take metal out,,,,,than to put it back in. Laughing Laughing
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  138 October 14th 2010, 11:22 pm
so if I have a set of headers for TFS A460's in a fox body (and I do-accufabs 2.25" prim.)... I can run tf streets, or scj heads and not have any major issues? Shocked
Do a460 headers fit p51s? Phelanjpg0141
138
Post  c.evans October 14th 2010, 11:28 pm
You may be able too if you have any kind of clearance at all. Those flanges are about 5/8" thick but they are also tapered due to the adjustment necessary for the outer Chevy head angle verse the Ford's outer head angle.
Another potential problem is the height of the A-460 exhaust port is higher by design,,,verses the SCJ & etc. exhaust port. So in essence you would be lowering the header some.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  138 October 14th 2010, 11:33 pm
hmmm.... good info tonite charlie... thanks!!! pirat
138
