Stock P51s vs Ported P51s
138
psfracer
Stock P51s vs Ported P51s Empty Stock P51s vs Ported P51s
Post  psfracer July 2nd 2011, 9:16 pm
Does anyone have any data on this? How much is port work worth on the P51? The intakes look really good, but I imagine some could be picked up on the exhaust side? Is it worth the money to have some P51s ported? Does anyone have any flow #'s on a set that was ported? Stock they are supposed to be very close to 400 on the intake side.
Combo:
572 cid 4.500 X 4.500
16:1 compression
Cam 284 @ .050 / .773 lift intake, 296 @ .050 / .749 lift exhaust on a 112 lobe center
1250 cfm dominator, TFS intake
With stock P51s 924 hp @ 6900. Over 900 from 6300 to 7400.
psfracer
psfracer
http://www.psfracer.com
Stock P51s vs Ported P51s Empty Re: Stock P51s vs Ported P51s
Post  rmcomprandy July 2nd 2011, 9:26 pm
BOTH sides can be improved considerably at the higher valve lifts.
430 and 275 is a considerable improvement.
Post  138 July 2nd 2011, 9:26 pm
fabio has that data.... look in his build
Stock P51s vs Ported P51s TV10-17-09-8
138
Post  IDT-572 July 2nd 2011, 9:44 pm
psfracer wrote:Does anyone have any data on this? How much is port work worth on the P51? The intakes look really good, but I imagine some could be picked up on the exhaust side? Is it worth the money to have some P51s ported? Does anyone have any flow #'s on a set that was ported? Stock they are supposed to be very close to 400 on the intake side.
Combo:
16:1 compression
They don't flow 400 out of the box now. but it's easy to get them to.
You need more split and lift also..................
Post  psfracer July 2nd 2011, 9:52 pm
So what that would translate to hp wise? I know that would depend on many factors, but would it reasonable to assume I could pick up 30-40hp with port work?
psfracer
psfracer
Post  Lem Evans July 2nd 2011, 10:16 pm
The cam info you posted showed the intake lobe to be 282* @ .050"..........not 284*
Post  Lem Evans July 2nd 2011, 10:18 pm
What's you rocker ratio?
Post  psfracer July 2nd 2011, 10:44 pm
1.75 is the rocker ratio. Oh yea, 282 not 284.
psfracer
psfracer
Post  Lem Evans July 2nd 2011, 10:46 pm
1.75 X .455" = .796" lift. intake.
Post  psfracer July 2nd 2011, 11:02 pm
Yeah, so the exhaust would be at .771 because of the 1.75 ratio vs the 1.70--I forgot about that. Then take out the .018 clearance which would make it .753 exhaust, and .778 intake.
psfracer
psfracer
Post  c.evans July 3rd 2011, 2:05 pm
psfracer wrote:So what that would translate to hp wise? I know that would depend on many factors, but would it reasonable to assume I could pick up 30-40hp with port work?
Let's do the math.
1. You have had your engine dynoed and it made 924 Hp out of 572 cubic inches. 924/572 = 1.615 Hp/cu.in.
2. Randy Moore's (KY Mustang) is very similiar to yours, but not as much compresion. It has fully ported P-51 heads with titanium 2.300" intake valves. It made 951 Hp out of 562 cubic inches. 951/562 = 1.692 Hp/cu.in.
3. Bobby Shrewsberry's engine is very similiar to yours, but not as much compression. it had fully ported P-51 heads with stainless steel 2.300" valves. It made 942 Hp out of 559 cubic inches. 942/559 = 1.685 Hp/cu.in.
Both engines made more per CID than yours did. Using their higher Hp/cu.in values, your 572 CID engine should make between 963.8 to 967.8 Hp. Let's split the difference and say 965.8 Hp.
965.8 Hp minus your present 924 Hp equals an increase of 41.8 Hp. So 965.8 - 924 = 41.8 hp which you are asking for 30 to 40 hp more. Therefore I say yes, to answer your question and I highly recommend porting and flow testing your heads.
Charlie Evans
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  psfracer July 3rd 2011, 2:26 pm
Great post. The math looks good to me.
psfracer
psfracer
Post  richter69 July 3rd 2011, 2:30 pm
The Snake made over 1000hp with his 570" deal............ Wink
Post  IDT-572 July 3rd 2011, 3:27 pm
richter69 wrote:The Snake made over 1000hp with his 570" deal............ Wink
580 inch 1003/580 = 1.73 hp per cid.
Porting the heads is more than worth the effort. Give Charlie a call................ Cool And call Lem on the cam Wink
They like something different in the cam department than your normal scj deals use.
Post  richter69 July 3rd 2011, 3:36 pm
my bad on the typo lol.
Post  Lem Evans July 5th 2011, 9:57 am
Let's do the math.
Charlie Evans
Randy's and Bobby's engines were not dynoed without a vacuum pump. Paul's engine has a pump. Having said that, I'd think Paul's engine with ported heads could be 980ish for HP.
