HOTTEST and COLDEST PLUG???
Barney
1Bad91
HOTTEST and COLDEST PLUG??? Empty HOTTEST and COLDEST PLUG???
Post  1Bad91 October 14th 2010, 2:02 pm
Can anybody tell me the Coldest to hottest plug to use with DOVE heads W/out using adapters? I'm looking at stocking up on some plugs and would like to know what you guys recommend. I wouldn't mind knowing each the brands you guys are using too.
1Bad91
1Bad91
HOTTEST and COLDEST PLUG??? Empty Re: HOTTEST and COLDEST PLUG???
Post  dfree383 October 14th 2010, 2:05 pm
I depends on the application, Blown? No2? Compression? Drag? Endurance? Street?
Post  1Bad91 October 14th 2010, 2:14 pm
I drive it on street and track. See's mostly track but just under 10:1 compression. and set-up of NO2. Right now concentrating on all motor runs till I get the tune right.
1Bad91
1Bad91
Post  dfree383 October 14th 2010, 2:21 pm
The Factory Heat Range is Probalby sufficient at 10:1, and go colder depending on the shot you intend to use.
Post  1Bad91 October 14th 2010, 2:44 pm
looking for heat range reference numbers. Thanks
1Bad91
1Bad91
Post  Barney October 14th 2010, 2:58 pm
This was already covered in the N2O section at length.
Barney
Barney
Post  1Bad91 October 14th 2010, 3:02 pm
it was discussed primarily for cold plugs. I'm looking for a guide line for both hot and cold plugs.
1Bad91
1Bad91
Post  Lem Evans October 14th 2010, 4:18 pm
AR32........coldest 18mm autolite has.
AR33..........next hottest
124............"""""""""""""""
45.............,""""""""""""""""""""
Post  1Bad91 October 14th 2010, 4:35 pm
Lem Evans wrote:AR32........coldest 18mm autolite has.
Lem, and hottest?
1Bad91
1Bad91
Post  1Bad91 October 15th 2010, 1:32 pm
Can anybody refer me to the hottest plug 18mm for Autolight?
1Bad91
1Bad91
Post  res0rli9 October 15th 2010, 1:34 pm
The Factory Heat Range is Probalby the hottest
Post  Barney October 15th 2010, 1:47 pm
Autolite.com
Barney
Barney
Post  whatbumper October 15th 2010, 1:49 pm
I wouldn't know why anyone would go hotter than the factory plugs.
Post  bbf-falcon October 16th 2010, 1:11 pm
I think Lem just said it....45 Smile
Post  BOSS 429 October 16th 2010, 11:09 pm
that might confuse him, he probaly has the big plug, and its hard to find a brf or bf 32 these days, w/ 10 to 1 or so id start with a brf 42, your best bet would be buy the adp's then you will have all kinds of choices , they use the .750 reach, warsher type,
-rich
Post  bbf-falcon October 17th 2010, 8:23 am
A friend of mine that used to be a parts manager at a local ford dealership that bellied up yrs ago,had a bunch of new bf 22/32's new in box's yet. I could check w/him if anybody needs them.
Post  Lem Evans October 17th 2010, 9:45 am
-rich
Those are 18mm [big] part #s.
Post  BOSS 429 October 17th 2010, 10:17 am
im blind sometimes i guess, i saw the a,and went from there not thinking,lol af42 /bf42,lol
Post  k.pascoe October 18th 2010, 2:19 pm
Try the Motorcraft BTF-1 It's the plug to run.
k.pascoe
Post  1Bad91 October 18th 2010, 3:19 pm
Thanks for all the help
1Bad91
1Bad91
