mid plate thickness...
any thoughts?
basically my converter is set up for an JW ultra bell, powerglide with a .090 mid plate.. I'm needing a mid plate and this is what he has.. on another note, being that the converter is setup for a JW ultra,would it make a difference if I went with a Reid case, and bell or an ATI adapter plate set-up?
138 wrote:my converter is setup for a .090 mid-plate...any thoughts? I have not a clue
96Mustang460cid wrote:I measured 0.117". As a minor correction, the plate was cut for a 96 Mustang. Everything I've read said they're the same...just in case, though .
Have a good day!
Michael
96Mustang460cid wrote:A difference of 0.030" is not a big deal, IMHO. Basically, the converter will have 0.030" less engagement in the crankshaft. Considering that many guys (myself included) run a mid-plate with OEM (measurement) mid-plates without a problem and that's a lot more than 0.030" difference.
Feel free to call me to discuss.
Have a good day!
Michael
918-760-8450
138- Posts : 1593
Re: mid plate thickness...
so.......are you saying he has a 1/8 mid plate?if so it wouldnt be a problem,just shim the converter a little.more room is better than not enough.
first sure you need one? .200 or .190 is the thinest i would consider
BOSS 429- Posts : 2372
yeah I'm gonna run one... this one is steele... and I have not a clue on converters and mid plates so....
138- Posts : 1593
» SFI spec thickness of engine plate
» Water pump backing plate thickness?
» Looking for opinions on motor plate / mid plate vs solid mounts / no mid plate on a fox body .
» Cam thrust plate and water pump baking plate questions
» BBF Starter Locator Plate and Steel Mid Plate
